November 22, 2024, 10:11:00 pm *
Pages: [1] 2 3 4  All
Author Topic: Burst of noise  (Read 47904 times)
dsm
« on: October 02, 2017, 12:27:19 am »
Hello Peter,
A couple times now using 2.08d,  I've had a burst of high volume static come through the speakers. It seems to happen when playing only one or two songs on a playlist and the noise comes in at about 5 to 10 second after the music starts and scares the heck out of me. I have to quickly turn off the amp and stop XXHighEnd.
The static sound is the same which would happen on XXHighEnd a couple of years ago when repeatedly pressing down the volume to quickly.
I did not have this happen on 2.07.  Do you have any ideas what could cause this?
David
« Reply #1 on: October 02, 2017, 08:24:15 am »
Hi David,
I recall I had this one time maybe 2 months ago. But then it happens maybe once a year to begin with.
I am positive this is because you do something in advance of which you can see or feel it ain't right. Example : Press Stop - change your mind and press Play again within half of a second. This is only an example.
So carefully think what you might have done in advance of this, and tell me so I can look into it.
It should be coincidence but thus may depend on your "workflow". Like you said it yourself from previous times : change the volume fast. I know that if we do this today, sound will stop. Or worse ... O I taught mysef to not change the volume fast. But then this is not necessary any more.
Notice that with Alt-s (see XXOSK.exe and the S on it) the music stops instantly. So always have that on screen (you should anyway), and now you can stop the possible noise as fast as you are yourself.
If you use a quite random SFS number (and not a calculated one for your own reasons) then you can add/subtract 0.1 to.from it. This does matter, as all is relatively fragile inside for things coming together which should not. So if you just changed something regarding (all) these settings, it easily can be bad luck on the combination.
I hope I am clear enough on wanting to solve this, instead of you being able to deal with this ... But it needs the example !
« Reply #2 on: October 03, 2017, 07:26:55 pm »
OK, I just had it myself. This was the sequence :
I played a 24/96 (actually an MQA but I regard this unimportant) which ended by itself because of the end of the album (this could be crucial).
I put on a next album of 16/44.1 and selected 4 tracks (I don't think this is important, but mentioning it just in case).
With my SFS of 0.9 I estimate that the 3rd buffer of that ended up in a burst of noise. But only during the length of that buffer (which should be 0.8 seconds or so (at 705600 samples per second). After that all went back to normal.
Side note : I recognize that it can happen during the length of one SFS buffer size only - for years by now. Also : the shorter/smaller the SFS, the shorter the noise lasts.
I stopped and restarted playback of the same selection, just because I was curious.
Nothing happened this time.
This latter proves to me that it should be related to what happened prior to the issue.
dsm
« Reply #3 on: October 03, 2017, 11:59:49 pm »
I can't say I have been too interested in trying to replicate this but it has  seemed to only happen when trying to play a 1 to 3 song playlist in Unattended (always Redbook). I have not  had a problem with a full album.
I think one time the static happened at the beginning of the second song in unattended.  Today, I have only been playing albums so everything has worked perfect and btw, I am using your settings with the .9 SFS.
I know this is not too informative, but I wanted to post in case it happens to someone else.
David
« Reply #4 on: October 04, 2017, 08:03:40 am »
Hi David,
If you are sure it was the second track and not just the first, then think (consider) of something in your PC not responding fast enough. But combine this with your experience of the lower SFS setting. So have you had this lower before then this shouldn't be the issue (so let me know what you used for lower for a longer period of time (like weeks)).
Also look at the length of this first track you played; was this considerably longer than average, you can have ran into the situation that too much in the PC fell asleep (not the whole PC of course). And now with the small SFS of 0.9, it does not wake up in time. This should not result in the noise, but by accidental combinations of matters, it could.
Arjan
« Reply #5 on: October 17, 2017, 12:18:17 pm »
Had the same issue of burst of noise now 2 times with 2.08a.
The first time it was 2 bursts after each other. The second time was just one burst.
The second time (I do not recall the first time) the music stopped after the burst.
I just restarted the track and no issues.
It is a bit scary. Any clues on this issue? I have never heard this kind of noise burst before. I know of cracks and other short ticks but this is different.
My SFS is at 2 so not long but also not ultra short. Should it be longer, but the burst will be longer too. Or shorter?
regards, Arjan
March, 2024 (2.11)
« Reply #6 on: October 17, 2017, 02:13:09 pm »
Arjan,
Hmm ...
In any event the shorter the SFS the sorther the burst. Coincidentally I changed mine from 0.9 to 1.5 yesterday, so maybe I can recognize it starts to happen to me too (it did once for 2.08 but I have it 1-2 times per year anyway (1 time will be closer to the truth)).
What is your Q1/xQ1 ? (mine is 14/1)
Arjan
« Reply #7 on: October 21, 2017, 01:35:23 pm »
I use the same Q1/xQ1 setting. Changed to SFS 1.5, from 2.
Last 2 days no burst of noise. But it was also more regular listening to complete albums.
It might have to do with using Alt-X and testing different parts of tracks.
Because when it happened I was testing the SQ for different tubes in the power amp. And I did that by playing parts of different tracks of albums. I select a track, use end after track and start unattended play. When the music starts I use Alt-X to get back into the UI so I can use the sliders to set the volume or stop playing. But then again the burst of noise only happens 2 times....... so it is rare and difficult to reproduce.
To be honest I also do not want to reproduce this, because it is scary.
So hopefully when it happens again I remember the scenario that led to this.
Regards, Arjan
March, 2024 (2.11)
« Reply #8 on: October 21, 2017, 03:53:07 pm »
Hi Arjan,
Maybe it is not the best idea to cange the volume by means of XXHighEnd in that (Unattended) fashion. So if it happens you you like that only, then we can bet it is that (for your situation). Also, this is never tested of course. Also not by me and as you actually just told, when I'd try 10 times of course nothing goes wrong. So it should be used by a 100 people each day 20 times, and then we'd have a nice test base. But I am afraid you are the only one ...
briefremarks
« Reply #9 on: October 22, 2017, 06:05:20 am »
Just upgraded to 2.08d.  After playing several albums with no issue (all Attended), I just loaded another album and as I started the first track (also in Attended mode) experienced my first "burst of noise" incident.  Short.  I have NEVER experienced this with XXHE in all the years of use.  So my guess is that something has changed with 2.08d.  My current settings are in my signature.
Not sure if there is something to be done.  I will report if this happens again, and then perhaps try different SFS.
Ramesh
XXHE version 2.11.
« Reply #10 on: October 22, 2017, 08:33:08 am »
Ramesh, did you all these years play Attendedly so regularly ?
briefremarks
« Reply #11 on: October 22, 2017, 10:03:02 am »
I played in Attended mode a lot, especially when experimenting with albums to see if I liked them or not.
I think I may have found the sequence that causes the burst--not 100% sure.  Load the album, then select the first track again in the playlist, then play.  Happened twice, and I suspect it is this sequence.
Ramesh
XXHE version 2.11.
« Reply #12 on: October 22, 2017, 12:41:22 pm »
Hi Ramesh,
Can you eleborate on this please ?
So supposed the first track is automatically selected (is it ?), select it "again" would un-select it.
« Reply #13 on: October 22, 2017, 12:43:04 pm »
What I noticed myself yesterday at changing the volume after the GUI has been brought up (Unattended Playback commencing), was that clearly I ended up in another part of the track (maybe only 1 second further or earlier, but not "adjacent" as should). So this already looks dangerous to me ...
dsm
« Reply #14 on: October 22, 2017, 04:10:44 pm »
Please excuse my ignorance about all this but on other previous versions of XXHE, the burst of noise would only happen for me if I rapidly adjusted the volume in unattended, say if the phone rang or something and I tried to quickly turn it down.
I don't know how you implemented the instant volume and track changes with the new hotkeys, but is there any way they can be related? It seems the trouble happens with only one or two tracks in a playlist and not really with full albums.  Is there a too quick "turn around" which happens during a quick loading of one or two tracks which does not happen when the computer takes it's time loading an album worth of tracks?
By the way, I never received the burst of  noise when adjusting the SFS, even to extremes. I would just get clicks and such.
