November 23, 2024, 10:21:21 am *
Author Topic: 2.08d on WS2016 first impressions  (Read 22278 times)
bodiebill
« Reply #15 on: October 02, 2017, 10:06:47 pm »
PS: But still waiting on that Group Policy thing, because at this moment (2.08e) something is On which can be Off.
I did not want to celebrate too soon, but indeed no more group policy thing since 2.08e.
Windows 10 Enterprise LTSB 1607 build 14393.0 (tentative settings, still experimenting)
HDPlex 100W Linear PSU / Streacom FC5 / HDPLEX 250W Hi-Fi DC-ATX PS converter / Supermicro X11SAE -> Intel i3-6100T with Hyperthreading Off (2 cores), C-States Off, ECC RAM 16GB / music on LAN / XXHighEnd on A: (3GB RAMDisk) / Engine#4 Adaptive Mode / Q1=14, Q3=1, Q4=1, Q5=1 / Q1Factor = 1 / Dev.Buffer = 2048 / ClockRes = 15ms / Memory = Straight Contiguous / Include Garbage Collect / SFS = 0,1 (max 60) / not Invert / Phase Alignment Off / PlayerPrio = Low / ThreadPrio = Realtime / Scheme = No Appointment / Not Switch Processors during Playback = Off/ Playback Drive B: (3GB RAMDisk) / UnAttended (Just Start) / Stop Desktop-, Remaining-, WASAPI-Services / Keep LAN - Not Persist / Don't do anything with WallPaper / Minimize OS / XTweaks : Balanced Load = 43 / Nervous Rate = 1 / Cool when Idle = n.a. / Provide Stable Power = 0 / Utilize Cores always = 1 / Time Performance Index = *Optimal* / Time Stability = *Stable* / Custom Filter *Low* 705600 / Upsampling ? / -> USB3 *from MoBo* -> Lampizator USB cable -> nas4free music server or local MS-EX SLC usb drive / HDPlex Linear PSU / Streacom FC5 PC i3-6100T 16GB RAM / Windows 10 Enterprise LTSB / XXHighEnd  with minimized OS / APlayer with foo_dsd_asio (optional: Audiophile Optimizer 2.20b5 / Fidelizer Pro ) or WTFplay (Linux) / SOtM tX-USBhubEX / Audiophilleo 1 + Pure Power + Audio Aéro Prestige Signature or Uptone Regen + Lampizator Lite 7 DSD256 / Lightspeed Attenuator / Cayin A-88T / Spendor SP100 + 2x REL T5 / Taket H2 + TR2; Hifiman HE-6
« Reply #16 on: October 03, 2017, 11:10:11 am »
OK Dennis, thank you.
In the end of the afternoon I plan to have a 2.08f which theoretically also won't nag about the Group Policy thing. But then in the way I like it.
« Reply #17 on: October 04, 2017, 08:49:05 am »
Ahum - That end of the afternoon became later than planned and in the end it never happened. I will do it today now !
bodiebill
« Reply #18 on: October 04, 2017, 03:57:06 pm »
great Peter, at your ease! thx Dennis
« Reply #19 on: October 04, 2017, 05:52:23 pm »
Well Dennis, it now appears that I can't do much about that Group Policy matter, other than let it be as it is now. But still a small attempt :
Can you try to explain when this message "Waiting for Group Policy" appears, and also how it disappears. Maybe in other words : could it be bearable if we bring the situation back to 2.07d (I think it was).
At this moment, and without looking, I'd say that this message can there be forever, unless you start playback again. And then still it can be "bearable". And for example, if you need to click it away, then I would not like this ...
bodiebill
« Reply #20 on: October 04, 2017, 07:00:51 pm »
If I remember well, it was an occasional blue screen which just froze when I tried to stop or restart the pc, with the 'waiting circle'.
I then had to hard-shutdown.
Do you advise to go back to 2.08d? If I do I can give you a more precise description.
Alas, I am going on holiday Saturday for 2 weeks, and it is extra busy right now, but I will try to make some time for this.
Best, Dennis
« Reply #21 on: October 05, 2017, 04:41:04 am »
Thank you Dennis, but I think there is no need for this. The process of concern wants to start but can't. That is, I tried myself (emulated in 14393.0 Desktop version) and couldn't and then found my own documentation that I gave up on this a few years ago already. Point is : the destkop versions don't need it so once shut off in the proper way it stays away (and can only be restarted in normal OS), but apparently your WS2016 requires it and indeed can't start it herself just the same. So, dead end.
For net result it now is not shut down so nothing nags.
For more net result the server version could be somewhat less good sounding, although I never tested it (I have it but never felt tempted to install it for real and try it). And maybe to keep in mind : a Server version won't be different after all the stripping-off XXHighEnd does with the Desktop versions.
So Dennis, what you could do with some more available time, later, is compare your WS2016 with normal 14393.0.
Also to remember : your WS2016 is not of the 14393.0 "base" but is of a hihger Build number (14393.0 is the one officially supported by XXHighEnd). But don't ask me where to get the Server version with Build 14393.0.
Btw, changes will be very very small 14393.0 suddenly will be OK on this matter, as the Group Polily features will be too much in the heart of a Server (version).
So let's say it is okay as it is and that I am glad we could get it running without me having it running myself. Thanks to you of course !
bodiebill
« Reply #22 on: October 06, 2017, 12:15:00 am »
Agreed Peter. I appreciate it that you spend time on WS2016 without running it yourself, and still made it work pretty close to 100%.
Thanks for that! Dennis
