April 19, 2025, 04:52:50 pm *
Author Topic: Upgrade question from a greenhorn  (Read 5170 times)
bodiebill
« on: October 01, 2017, 07:18:05 pm »
To upgrade, should I unrar the XXHighEnd-208d-UpgradePatchOver204AndBeyond.rar file and then copy its contents into my existing XXHighEnd-207 folder?
And afterwards rename that folder to XXHighEnd-208?
And what should I do with the 208VCRT-x64.rar file?
Sorry about this, but I never upgraded before :-|
When I succeed, I will be looking forward to testing 2.08 with WS2016!
Windows 10 Enterprise LTSB 1607 build 14393.0 (tentative settings, still experimenting)
HDPlex 100W Linear PSU / Streacom FC5 / HDPLEX 250W Hi-Fi DC-ATX PS converter / Supermicro X11SAE -> Intel i3-6100T with Hyperthreading Off (2 cores), C-States Off, ECC RAM 16GB / music on LAN / XXHighEnd on A: (3GB RAMDisk) / Engine#4 Adaptive Mode / Q1=14, Q3=1, Q4=1, Q5=1 / Q1Factor = 1 / Dev.Buffer = 2048 / ClockRes = 15ms / Memory = Straight Contiguous / Include Garbage Collect / SFS = 0,1 (max 60) / not Invert / Phase Alignment Off / PlayerPrio = Low / ThreadPrio = Realtime / Scheme = No Appointment / Not Switch Processors during Playback = Off/ Playback Drive B: (3GB RAMDisk) / UnAttended (Just Start) / Stop Desktop-, Remaining-, WASAPI-Services / Keep LAN - Not Persist / Don't do anything with WallPaper / Minimize OS / XTweaks : Balanced Load = 43 / Nervous Rate = 1 / Cool when Idle = n.a. / Provide Stable Power = 0 / Utilize Cores always = 1 / Time Performance Index = *Optimal* / Time Stability = *Stable* / Custom Filter *Low* 705600 / Upsampling ? / -> USB3 *from MoBo* -> Lampizator USB cable -> nas4free music server or local MS-EX SLC usb drive / HDPlex Linear PSU / Streacom FC5 PC i3-6100T 16GB RAM / Windows 10 Enterprise LTSB / XXHighEnd  with minimized OS / APlayer with foo_dsd_asio (optional: Audiophile Optimizer 2.20b5 / Fidelizer Pro ) or WTFplay (Linux) / SOtM tX-USBhubEX / Audiophilleo 1 + Pure Power + Audio Aéro Prestige Signature or Uptone Regen + Lampizator Lite 7 DSD256 / Lightspeed Attenuator / Cayin A-88T / Spendor SP100 + 2x REL T5 / Taket H2 + TR2; Hifiman HE-6
« Reply #1 on: October 01, 2017, 07:25:59 pm »
Haha Dennis,
Indeed, just paste the upgrade patch over your current XX folder (don't forget to unzip it).
First kill XXEngine3.exe and AutoHotkey.exe with Taskmanager.
Do NOT rename anything. So if your path now contains "2.07" or something, bad luck.
Good luck now !
bodiebill
« Reply #2 on: October 01, 2017, 07:34:03 pm »
Thanks Peter, done (so easy!).
When I see anything worth notice in relation to WS2016 I will post it.
Cheers, Dennis
Page created in 9.501 seconds with 19 queries.
