April 19, 2025, 11:39:15 pm *
Author Topic: 2.08a Volume Isuue  (Read 9597 times)
« on: September 29, 2017, 09:13:42 pm »
 Peter, in unattended, volume won't change using laptop/server keyboard commands ALT/U and ALT/D. Alt/X (Stop) works fine. Same result trying the XXOSK. Otherwise, works and sounds great!
« Reply #1 on: September 30, 2017, 04:45:52 am »
Hi Brian,
What is your SFS and how are your Q settings ?
(I use 0.90 and Q1=14x1, Q3,4,5 = 1,1,1)
Robert
« Reply #2 on: September 30, 2017, 09:42:52 am »
Aha Peter some new settings for 2.08a. What about Q10?
I'm finding a new level of detail, so much that a vinyl rip has been exposed as I hear a scratch never heard before.
Robert
Oppo 205 UDP Dac
JLAudio 12 Active Subs x 2
« Reply #3 on: September 30, 2017, 12:20:27 pm »
What about Q10?
I changed my sig now ...
Thanks !
« Reply #4 on: September 30, 2017, 02:44:13 pm »
Thanks Peter, will try those settings. Probably take a few days as we are away for the weekend.
Robert
« Reply #5 on: October 01, 2017, 04:25:16 am »
Peter tried those settings only got bad stuttering, back to old settings.
Sometimes with 2.08a startup getting regular ticks in playback music. Only fixed by crossing out XXhighend and restarting.
Oppo 205 UDP Dac
« Reply #6 on: October 01, 2017, 12:01:45 pm »
Robert,
This looks to be an issue with your PC settings. So especially when you never tried these lower settings with the PC you use at this moment, I could be right on this.
If you think it is 2.08 then please open a new topic for it.
« Reply #7 on: October 05, 2017, 07:16:48 pm »
Guys,
The issue with the Volume not wanting to change, is "caused" by the Wallpaper Coverart set to not show. So when you'd change that setting, the Volume works.
I know, you have it off for a reason, so working on it !
« Reply #8 on: October 05, 2017, 09:08:47 pm »
Thanks Peter. I hadn't got back to this but will now wait for the fix. In the meantime am using 2.07.
