November 22, 2024, 08:47:01 pm *
Author Topic: Spaces in filepath on fresh install  (Read 6701 times)
« on: September 27, 2017, 10:02:24 pm »
I tried to install vs. 2.08 on my laptop which was XXHE-free previously.
It wont start when I click on xxhighend.exe.
It says I installed it in a folder with spaces in the name.
But where are the spaces in C:\XXHE?
Did I mess up/not read all the info / something else?
Gerard.
« Reply #1 on: September 28, 2017, 08:01:59 am »
Hi Gerard,
Possibly you do not start XXHighEnd.exe from within that same C:\XXHE folder ?
So can you try to go to that folder with Explorer and try from there ?
« Reply #2 on: September 29, 2017, 09:33:03 am »
That's the way I did it.
Tried a new unzip in a new folder but same result.
« Reply #3 on: September 29, 2017, 03:27:28 pm »
Stupid thought :
Have the old 2.07 running.
Paste the Upgrade patch over it.
Rightclick on Pause will show the path (and should show a space somehow).
... Then I will know the cause, hopefully.
After this you can paste back the 2.07 UpgradePatch (like in case 2.08 does not start at all for the same reason).
« Reply #4 on: October 01, 2017, 02:51:15 pm »
This is solved now and concerned a stupid mistake.
There's a new 2.08d for it in here.
