April 07, 2025, 01:35:28 am *
Author Topic: 2.08a does not save settings from RAM Disk  (Read 6285 times)
coliny
« on: September 26, 2017, 10:43:33 am »
Hi Peter
Running XXHE on RAM Disk the setting are not saved after reboot. A problem we had before.
Regards
Colin
« Reply #1 on: September 26, 2017, 10:51:21 am »
... and always found by you ...
I seriously wonder what I have done wrong this time because I don't recall I changed anything. BUT, in fact it was on my ToDo already (in vague fashion) because this time it (also) counts for the RAM-OS Disk (RAM) situation. So what I taught myself is explicitly saving in advance of the reboot.
Colin, does that work for your situation ? (see rightclick on Stop and the hopefully visible Save option)
coliny
« Reply #2 on: September 26, 2017, 05:11:56 pm »
My mistake, I had change the XXHE folder name but forgot to change the Setting "copy settings to.....".
BTW Save option is not available, its grey.
Thanks
Colin
« Reply #3 on: September 26, 2017, 05:16:26 pm »
OK Colin, great. Thank you for the feedback.
