April 07, 2025, 02:48:46 am *
Author Topic: 2.08 Error  (Read 21067 times)
« Reply #15 on: September 25, 2017, 05:11:36 pm »
OK David, thank you.
But now I still don't know whether you receive the exact same messages when you reject the question of the popup. IOW, is that the cause ?
« Reply #16 on: September 25, 2017, 05:15:43 pm »
I just did a fresh install on my W10 audio PC and all just works ...
(just a data point)
« Reply #17 on: September 25, 2017, 05:57:24 pm »
Can you quickly try the version below ?
Just paste over your XX folder.
Edit : Removed the download after David tested it, to avoid confusion for others.
dsm
« Reply #18 on: September 25, 2017, 06:08:02 pm »
Ha! you're a genius Peter. Tried both attended and unattended and it seems to be working fine.
As far as the user control "let this app make changes to your computer" on the desktop- I don't mind accepting but because this message never appeared with 2.07, I am  hesitant.
Best,
David
« Reply #19 on: September 25, 2017, 06:17:49 pm »
Thank you David ! For the fast response too.
You don't need to worry. But point could be : wouldn't it be necessary to always and ever respond to that message ?
Otherwise I am interested in the Registry Key(s) involved. If possible and not too much trouble you can please send this data to me by email (screenshot perhaps ?).
Thank you very much for your help.
« Reply #20 on: September 25, 2017, 06:33:40 pm »
OK, there is a new 2.08a up.
Everybody thanks for the patience.
Robert and David, thank you for your help.
Robert
« Reply #21 on: September 25, 2017, 09:01:32 pm »
Yes had to go to bed what with daylight saving kicking in.
2.08a working fine no glitches. Glad to help.
Robert
Oppo 205 UDP Dac
JLAudio 12 Active Subs x 2
Page created in 0.016 seconds with 19 queries.
