November 23, 2024, 05:54:37 am *
Author Topic: Findings / hiccups / questions  (Read 20589 times)
bodiebill
« Reply #15 on: September 09, 2017, 12:59:44 pm »
If you switch on Logging (at the bottom in Settings), in your XX folder a subfolder TemporaryData will contain log files;
Could you, with a next attempt to make the Restore Point, attach (to a post) the newest XX- log file (only XX-, no others are needed) ?
I don't recognize any "not found" situation, so it could be a server thing.
Take your time for this - no rush.
Done: you have mail.
I suppose you read this one, right ? Installing and using a RAMDisk (IMDisk)
Yes, works like a charm.
I wonder why ... This should normally work.
And ctrl-alt-esc works in Normal OS ?
Btw, if you (can ?) start TaskManager in advance of Unattended playback, it will keep on running.
Yes, both work in normal OS. But thanks for your suggestion to start TM before going Unattended, which it allowed me to count the processes and threads: P19, T257, nice and lean!
On a side note, don't forget to use XXOSK.Exe and then in the "square" mode. You will see soon how convenient that is. And notice you can resize it by means of dragging the "title bar" corners. Also set "Use Touch Facilities" in Settings (Services and OSD section), when you use the remote for control.
Nice little tool, will get acquainted with it... You thought of everything!
Is it correct that still no Wallpaper shows ?
Wallpaper is showing!
PS: For 2.08 WS2016 is now formally supported, but so far without special adjustments for it (I just don't know any yet).
Great news!
Something new:
Since making the recent changes my OS now says, in the lower right corner, 'Test Mode'. Is this expected?
Best, Dennis
Windows 10 Enterprise LTSB 1607 build 14393.0 (tentative settings, still experimenting)
HDPlex 100W Linear PSU / Streacom FC5 / HDPLEX 250W Hi-Fi DC-ATX PS converter / Supermicro X11SAE -> Intel i3-6100T with Hyperthreading Off (2 cores), C-States Off, ECC RAM 16GB / music on LAN / XXHighEnd on A: (3GB RAMDisk) / Engine#4 Adaptive Mode / Q1=14, Q3=1, Q4=1, Q5=1 / Q1Factor = 1 / Dev.Buffer = 2048 / ClockRes = 15ms / Memory = Straight Contiguous / Include Garbage Collect / SFS = 0,1 (max 60) / not Invert / Phase Alignment Off / PlayerPrio = Low / ThreadPrio = Realtime / Scheme = No Appointment / Not Switch Processors during Playback = Off/ Playback Drive B: (3GB RAMDisk) / UnAttended (Just Start) / Stop Desktop-, Remaining-, WASAPI-Services / Keep LAN - Not Persist / Don't do anything with WallPaper / Minimize OS / XTweaks : Balanced Load = 43 / Nervous Rate = 1 / Cool when Idle = n.a. / Provide Stable Power = 0 / Utilize Cores always = 1 / Time Performance Index = *Optimal* / Time Stability = *Stable* / Custom Filter *Low* 705600 / Upsampling ? / -> USB3 *from MoBo* -> Lampizator USB cable -> nas4free music server or local MS-EX SLC usb drive / HDPlex Linear PSU / Streacom FC5 PC i3-6100T 16GB RAM / Windows 10 Enterprise LTSB / XXHighEnd  with minimized OS / APlayer with foo_dsd_asio (optional: Audiophile Optimizer 2.20b5 / Fidelizer Pro ) or WTFplay (Linux) / SOtM tX-USBhubEX / Audiophilleo 1 + Pure Power + Audio Aéro Prestige Signature or Uptone Regen + Lampizator Lite 7 DSD256 / Lightspeed Attenuator / Cayin A-88T / Spendor SP100 + 2x REL T5 / Taket H2 + TR2; Hifiman HE-6
« Reply #16 on: September 09, 2017, 01:46:07 pm »
OK Dennis, great.
Well, I know at least one of the settings implies it. Not sure whether you could touch that but anyway it is a normal "feature". It doesn't do anything in itself (for SQ) but it allows for some OS settings to change.
Anyway it is perfectly normal.
Thanks. So this really looks like some feature missing on the server version, but actually I can't see much.
I don't think I asked already whether you can make a Restore Point yourself in Normal OS (no need to try in MinOS) ? So, can you ? (the answer is not even realy important)
Again thinking further ... the missing feauture can easily be caused by AO (just was never installed). Notice that this feature is not necessarily related to making Restore Points, but merely to a(n API) command set which is more rarely used (by programmers).
If you don't mind really, I prefer to let this be, just because we have no option to attach / debug the problem. What I will do anyway, is put in some log entries in there and if you can remember this, then at the time 2.08 is there you can retry again and we'll have a better log. But then still I am quite confident I won't be able to solve it. One thing though : we then could ask AudioPhil whether is disables the function of concern (this is hard to ask right now because there's quite a few things used in there).
bodiebill
« Reply #17 on: September 09, 2017, 02:02:03 pm »
OK, no problem then. It think it is rather an 'enhanced' state which allows more drivers to function.
Indeed certainly not an XX issue: I just found out that system restore points are not possible in Server 2016. There Windows Server Backup is the way to go, so I will use that.
(Or maybe you could just let some pop-up say "restore points not supported for this OS" or something.)
Best, Dennis
« Reply #18 on: September 09, 2017, 02:13:39 pm »
Just not at all, ever, you mean ?
Yep, good idea.
Yes, this is correct. I just looked, but you will have used the button "Refresh" tagged "Driver Signing ?"in the Output section in Settings. If you click the button when it shows "Refresh" you can click it and it will show "Change" (also observe the text preceeding the button). Click it once again, and all will be set to normal again (will require a reboot).
« Reply #19 on: September 09, 2017, 02:23:34 pm »
I now see that no Server version supports making Restore Points. In there it's something like "System State Backup".
For 2.08 I now silently skip the function (people should know, right ?  Happy).
Anyway, now we have a first "function" for WS2016. Haha.
bodiebill
« Reply #20 on: September 09, 2017, 02:39:42 pm »
Could not get rid of the test modus using refresh/change buttons – probably my bad. But I got rid of it using:
  bcdedit /set testsigning off
from the command line and rebooting.
Making a Windows Server Backup now... (while I will go do some shopping).
This only works when OS is not optimized, but that is expected and desireable I guess. Same applies to AO.
