November 23, 2024, 02:42:23 am *
Author Topic: Message 76 re missing file path from Library  (Read 6352 times)
Robert
« on: September 01, 2017, 06:48:59 am »
I did delete a music file probably at the wrong time. Everytime since I click on L button to load music library into Xxhigh a message comes up "76. Could not find a part of the path"
How can I delete this message please?
Not urgent but a pain. Perhaps when you return home from your holiday.
Robert
Oppo 205 UDP Dac
JLAudio 12 Active Subs x 2
« Reply #1 on: September 02, 2017, 11:47:24 pm »
Hi Robert,
Make a copy of your XXData folder.
Delete the file named !CurrentlyPlaying.[...].
Restart XXHighEnd.
IIRC this will help.
If not, also delete !Played.[...].
If now nothing works anymore, then restore the saved XXData folder and wait till I am back ...
HTH !
Robert
« Reply #2 on: September 03, 2017, 02:15:57 am »
Hi Peter tried suggestions but didn't work.
But I solved it by deleting the 2 data lines(missing file path from Library files) from "LibraryData.txt" file in 2.xx folder.
Everything working perfectly now. Thanks.
Looking forward to 2.08.
Robert
Oppo 205 UDP Dac
« Reply #3 on: September 03, 2017, 07:40:51 pm »
Robert, Super !
