April 02, 2025, 04:22:23 pm *
Author Topic: Moving entire galleries  (Read 11815 times)
charliemb
« on: July 28, 2017, 10:48:38 pm »
Hi Peter
1. How do I move all contents of my Nice Stuff gallery to the Show gallery?
2. Also, how do I delete a duplicate item within a gallery?
The situation for 2 is that if I like a track I hit Alt-c.  But it turns out I do that multiple times over the course of years because I can't remember whether or not I've hit alt-c before.  So I end up with unwanted duplicates.
Perhaps there is a new setting brewing here:
  • a "De-duplicate Galleries" button?  This button can clean everything up automatically, or
  • a "Prevent duplicates" button?  This can leave galleries as they are but check to make sure that new entries don't already exist
Thanks for your consideration
Charlie
July 2019:
« Reply #1 on: July 29, 2017, 06:24:41 am »
Charlie, only with trickery I would not even be able to accomplish myself.
So say it can't.
Just delete it. Notice that ubnder RighClick on the Library Item, there's a "More Gallery functions" option near the bottom in the context menu, and there reside the functions you seek for.
No, that is not how it works (or indeed you'll get mad). So I am afraid you already "manipulated" outside of XXHighEnd's functions, like copying Gallery folders or renaming them etc. etc. via Explorer.
Say that it is another subject how to get this right again. This too will be quite impossible, depending on the damaga done. Anyway :
When you use one of the "Put to Gallery" gallery functions, it creates meta data of the album in the Gallery Folder with the same name (but prefixed with the Gallery itself). Do this again, and it just does it again. No duplicate can emerge. However, copy the Original Location (folder) to elsewhere, play that and again use Alt-c etc. and you have the Gallery entry twice. Well, not really, because you have the Original also twice. So this is still consistent.
Now Rename the Original with Explorer to another name and things will go bad on you; you now renamed the Original but did not rename the Gallery, which you btw can not even do because there's also the metadata itself with related contents). Anyway, if you now plat from this newly named (location) and use Alt-c again, you indeed have two entries, but the old one is actually obsolete.
Do the problem really is that after the rename, the old one is a floating entry with reference to something which does not exist any more.
This is your base for understanding; it solves nothing (but if you have concrete questions, shoot them).
charliemb
« Reply #2 on: July 29, 2017, 03:02:18 pm »
So say it can't.
The need for this arises because I'm interested in individual tracks, not whole albums, and my understanding is that individual tracks are handled in the Show gallery.
Re deleting duplicates...
Just delete it. Notice that under RightClick on the Library Item, there's a "More Gallery functions" option near the bottom in the context menu, and there reside the functions you seek for.
I believe I tried that and it didn't work, as tested in the past by clearing and reloading and when I reloaded, duplicates appeared regardless.  Now maybe that was a cache issue or something like I needed to exit and restart xxHE.  I will have to reconfirm.
Say that it is another subject how to get this right again. This too will be quite impossible, depending on the damaga done. Anyway ...
I never copied Gallery folders, nor renamed them, nor moved them.  However, because rightClick functions were not working, I did try to use explorer to delete some.  But that didn't work because apparently, a duplicate Gallery metadata item is also placed in the "real" folder and from that it appears that the Gallery "repairs" itself.  [Frankly I don't like the idea that the real folder is littered with these Gallery files.  I'd prefer you create a folder and within that litter all you want, preferably a hidden folder.  Even more preferred would be,  don't touch the real folders at all, or at least have an option for that.]
The real / original folders and data and their locations on the disk have always been the same and have never changed.  Yet,  the filenames of the metadata files in the Galleries for these duplicates are indeed a little bit different.   That's a cliue.  Perhaps different versions of xxHE used different naming schemes?
July 2019:
« Reply #3 on: July 30, 2017, 11:23:43 am »
Charlie,
The majority of functions required for this - and so you can do all what's desired - only emerged way beyond the 2.01 you used.
Today it should be fairly complete because I don't recall having changed anything regarding this in the due 2.08. Maybe 2.07 also not any more.
We must also be carful about "nomenclature" by now, because the short keys changed.
AutoHotKeys (Remote Commands) Listing.
... And as it turns out, I don't even know them by heard any more because I always use the XXOSK.exe and use the remote + tap the shortcuts in there. Anyway :
What you can see in the link is that Alt-c has been deprecated and its major reason was that tracks could mix up with full albums. So this is explicitly dealt with in one of the  releasnote pages to the later versions. So if you have problems regarding that, it is justified (but I don't recall it to be a big deal, only confusing).
Anyway, what you are looking for is Alt-z, which puts to (the by you set) "Demo" Gallery. Change the relevant field from what you currently use for Show or IOW Alt-w.
The specialy of Show is that it can be dynamically changed (while using the remote). No "Show" is the same ... (or whatver reason you have yourself).
Alt-h copies to Nice Stuff and that is now always the whole Album.
Also notice Ctrl-Alt-h and Ctrl-Alt-z.
Or Ctrl-Alt-r - also crucial.
I hope this helps you a little ...
charliemb
« Reply #4 on: August 03, 2017, 01:05:19 am »
Hi Peter
If I understood correctly,  both Show (alt-w) and Demo (alt-z) deal with tracks, not whole albums.  True?
If true, then I can use either.  I still have no Gallery set for Show.   Up until now I've only used NiceStuff and Demo.   Unfortunately, I've been using Demo for tracks that are so-called "bad" recordings,  for example where there is obviously mic distortion etc.   I use these tracks to see how different settings affect "bad" recordings.
So probably the best thing I can do is starting using Show, and load the individual tracks of Nice Stuff and save them to Show;  then remove them from Nice Stuff all within xxHE.
-OR- One possible interpretation of what you wrote above, namely this...
... is that I can use the field for Show to point to the c:\xxHighEnd\Nice Stuff gallery ...  which would allow me to do what I want without moving anything just by using alt-w and by working from the Show gallery which on the disk is actually the Nice Stuff gallery's location.   (Not sure about this at all.)
Yes?  No?
July 2019:
« Reply #5 on: August 03, 2017, 01:35:34 pm »
Hi Charlie,
Your second option may be a tricky one, as at this moment I can not oversee what the consequences are for something which was "abum bounded" (Nice Stuff) and "track bounded" (Show / Demo).
The first option seems more safe to me. Thus indeed :
Because Show can be appointed dynamically (even during playing), Ot would "originally" be my idea that in there you also have a Bad Tracks. But this might not be the best idea at all, because you can run into bad tracks at any time and want to act fast (press Alt-z (Demo) - done).
Of course you have also seen the Ctrl-Alt-h and Ctrl-Alt-z (Album and Tracks respectively) buttons on the XXOSK.Exe, which imply dynamic allocation to anything (via "select via Tablet" - just look in there and you wil grasp it).
Lastly (because it may be confusing or look dangerous when you are not used to it), use the "Remove Gallery Selection from his Gallery" when you want to remove all the entries from that Gallery you just copied to another. But be sure to select the proper Gallery first !
And notice that what I refer to here is from within the Library Area (use [ L ] in the top). I think it is obvious, but just saying ...
