April 01, 2025, 05:34:31 am *
Pages: 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16  All
Author Topic: The Lush  (Read 278232 times)
« Reply #30 on: June 23, 2017, 03:28:14 pm »
WOW indeed...
 sounds good ! sounds good !
« Reply #31 on: June 23, 2017, 05:29:34 pm »
Hi Peter -  070cm for me please
fmanheck
« Reply #32 on: June 23, 2017, 10:18:16 pm »
I'm in
100cm for me too
fred
« Reply #33 on: June 24, 2017, 08:55:47 pm »
Peter, are your thoughts on the sound of the Lush dependent on it being connected to a Phisolator (or 3!), or is it still effective if connected directly to the NOS1's USB input C? If you are using a Phisolator, are you using the 'standard' short USB link between USB B and C on the NOS1? Have you tried a short Lush between B and C?
I'm in a position where I simply don't need a 'lusher' sound than I'm already getting (assuming I understood your initial description). I'm not using either of the Phisolators in my respective NOS1s (preferring instead to use Intonas) and I'm concerned that the Lush will take the sound in a direction I don't like. The Phisolator hasn't worked out for me, and I'm concerned that the Lush might not either.
Any advice on what I should do?
« Reply #34 on: June 25, 2017, 12:15:57 am »
In your case it is the best not to try it at all.
What one doesn't know, can't harm.
Really ?? Hahahaha
Now test yourself.
But really, just don't get it.
More really, just don't get it.
Or get it just in case but don't try it.
Bzzzz
« Reply #35 on: June 25, 2017, 03:36:35 am »
Maybe you could offer to do the hard yards and burn-in Pauls cable for him.
« Reply #36 on: June 25, 2017, 09:39:05 am »
I'm growing a real hatred for all things USB. It's like we're all being held hostage by its whims. And unfortunately, it has us by the balls...
And our knight in shining armour, instead of defeating it and putting it in its place, is courting it! Appeasing it. Complementing it. But its fickle nature remains lurking beneath the surface.
Whatever Paul touches turns to gold. I wouldn't want to break the spell.
« Reply #37 on: June 25, 2017, 11:10:16 am »
For those who already have the Lush:
Can you add to the expressions of wonder some other more descriptive detail? e.g. How you compare it to the Clairixa? Thanks
Peter, what really pushed you to create the Lush? Do you see it as a way to solve some lack of the Bass upgrade impossible to solve otherwise? If this is so, should it be understood as part of the Bass upgrade?
I'm not questioning anything here, just want to understand it better.
« Last Edit: June 26, 2017, 09:57:26 am by juanpmar » Logged
Arjan
« Reply #38 on: June 25, 2017, 03:07:21 pm »
I am using Lush now for 1 day. Very first impression, I am missing something. But within some tracks I started to appreciate the sound. Really smooth and warmer but with same details AND better bass again.
Maybe because I am used to tube amps the first impression was different from others, Clairixa is sharper.
Mani, I also tested with Clairixa some days ago with PE and without Phisolator. I did not liked that. To me Lush does something similar to the SQ BUT the right way!
Regards, Arjan
March, 2024 (2.11)
« Reply #39 on: June 25, 2017, 04:29:12 pm »
Thanks Arjan. If you are using tube amps and don't find the sound too warm then probably the Lush is working well in your system. When you say that the bass is better would you say that it also has a better definition?
Arjan
« Reply #40 on: June 25, 2017, 10:32:52 pm »
About the bass I would say, although it was never booming, it is now more bass feeling and less booming. A bit difficult to explain.
But for me it is singing now.
Regards, Arjan
March, 2024 (2.11)
« Reply #41 on: June 27, 2017, 06:49:38 am »
The main reason that I purchased a NOS1 way back when was that it was supposed to be immune to USB cables and I had just spent a boat load on a fancy USB cable after trialing many and thought there were better ways to spend my time (and money).  The NOS1 was more or less immune...inconsequential differences between USB cables and I was perfectly happy with the $2 cable that Peter had supplied with the dac.
Upgrades to NOS1a and now the G3 and no USB cable immunity has been set aside but the sound now is definitely better these days.  It is a little troubling that the dac that was once immune is no longer and that I have purchased both the Clairixa and The Lush expensive USB cables from Peter, but it is what it is.
Curious Cables are made just down the hill from me so I will see if I can get one sent up for a demo...in for a penny in for a pound!
« Reply #42 on: June 27, 2017, 08:42:14 am »
I think Ethernet needs to be looked at. It maybe the best solution to the USB inconsistencies. However Peter knows best.
« Reply #43 on: June 28, 2017, 06:25:32 am »
Perhaps it is because I am still in the honeymoon period (my The Lush arrived this morning) but this cable is "the business".  Harmonics anyone?  The albums that I have listened to so far have been very enjoyable.
Yes the sound is more lush, or perhaps even warmer, than the Clarixia.  It kind of reminds me of why people choose triodes and 4 or 5 way acoustic systems...that depth of presentation with a harmonic richness to soothe the soul.
Mani, would I use this cable in a triode/horn acoustic system?  Well it depends a little I guess.  If your sound is "rounded" rather than "clean" and already has lots and lots of H2 then perhaps this cable will bring too much, I am not sure.  Think a 300B pushed hard with a half decent OPT that struggles with both HF and LF (but has a midrange to die for)...I don't think The Lush will work there.  A well designed SET with a very capable output transformer matched to the loudspeakers and operated well within its limits, or optimally a multi-amp SET system, and this USB cable and the G3 will work very well.
I've not played with the Intona/Phisolator combo in and out of my system since the G3 upgrade, but I have no reason to want to do so with the solid state amplification that I am using at the moment.  That you have, and prefer the 'less rounded' sound of the Intona may be an indication that The Lush is not for you.  Or not, because I do not really know what you are hearing.
Peter, well done!  I'll leave The Lush in for a week or so and then try the Clarixia again.
Mani, I hope this helps a little with your decision.
« Reply #44 on: June 28, 2017, 09:20:36 am »
Anthony, that's really, really useful and very timely (I'll go into more detail in a short while). Thanks for taking the time to share your thoughts.
