« Reply #180 on: August 04, 2017, 02:26:38 pm » |
I guess Peter will contact me via email to complete the transaction? He will.  (via the address you use for the forum) Hey Wisnon, nice seeing you here. Will be the last time maybe, because this year I'll exchange Jamaica for Cuba. Maybe I won't find my way back. But we'll try to make your Lush in advance. Best regards, Peter
« Reply #181 on: August 04, 2017, 03:07:06 pm » |
Hi, Please can you send me a Lush USB cable: 1,5m?
Kind regards
I'm lushed now and it's beautiful to listen more and more and more and more Thank you !!
mikeg
« Reply #182 on: August 04, 2017, 03:11:10 pm » |
I would like a Lush 100cm.
Audio Reviewer
wisnon
« Reply #183 on: August 04, 2017, 03:34:21 pm » |
I guess Peter will contact me via email to complete the transaction? He will.  (via the address you use for the forum) Hey Wisnon, nice seeing you here. Will be the last time maybe, because this year I'll exchange Jamaica for Cuba. Maybe I won't find my way back. But we'll try to make your Lush in advance. Best regards, Peter Haha Cuba is VERY lovely too. My Grandfather and Granduncle both lived there in the long ago past and my cousin is married to a Cuban. Many in the Santiago region have Jamaican roots.
Trond
« Reply #184 on: August 05, 2017, 02:23:43 pm » |
Hello. I want to order a 70 cm Lush. Thank you.
« Reply #185 on: August 05, 2017, 03:01:46 pm » |
Hello. I want to order a 70 cm Lush. Thank you. Hi all, I hope that everybody can wait a bit for I respond, because I am currently setting up a kind of automatic ordering system. So please continue with your requests (in here or by email) which is good for the "first come first serve" sequence. But at some stage I hope to direct you to a kind of webshop. And if that fails, we proceed as usual. If all is right, everybody else in advance of Trond is already in the old procedure automatically. Thank you ! Peter
boyzclb
« Reply #186 on: August 05, 2017, 05:25:55 pm » |
Very interested in the Lush USB 1.5m cable.
barrows
« Reply #187 on: August 05, 2017, 06:09:25 pm » |
Barrows from Sonore here. I am currently looking to test a bunch of USB cables here with our Ethernet-USB device. This thing has a very good USB signal, but of course the cable still matters some. I would like to order a single 100 cm LUSH from ya...
Thanks!
« Reply #188 on: August 05, 2017, 08:52:06 pm » |
Hi all,
I think I have the webshop running, but I need to check and test thoroughly which will happen tomorrow. Right now it starts to be late over here (like 9pm and dinner yet to make) ...
Thank you for your patience. Your Lushes won't arrive a minute later because of this. Peter
PS: Remember, keep on announcing yourself until the webshop runs, because it will determine the supply sequence (in which batch you will be).
« Reply #189 on: August 06, 2017, 04:24:06 pm » |
Well, I created the smallest shop ever : Phasure Web ShopIn the end it wasn't easy at all to make some "decisions", mainly in the shipping department; I spent the whole day on that alone, to decide I better make something for that myself (later). All should be OK, but of course it is brand new. Nobody should worry that things will go really wrong, and in the end I am always here to refund if needed. If you have problems somewhere, just let me know and we will see what to do about it. Regards, Peter
« Reply #190 on: August 06, 2017, 04:37:13 pm » |
Thanks!
Hey Barrows, great to see you here. but of course the cable still matters some. Hahaha, wasn't it so that EVERYTHING matters ? Especially for you I added the Clairixa to the shop as well. And if I were you I'd order each of the evailable lengths of everything, because, well ... OK OK ... Thanks ! Peter
« Reply #191 on: August 06, 2017, 04:41:38 pm » |
Hello. I want to order a 70 cm Lush. Thank you. Trond, you are famous now for the first Phasure webshop order. And I an see the money, that makes it even better.  Thank you for being the dare devil of The First. Best regards, Peter
« Reply #192 on: August 06, 2017, 05:16:05 pm » |
That Lush looks nice against the blue sky  Juan
« Reply #193 on: August 06, 2017, 05:25:11 pm » |
Trond
« Reply #194 on: August 07, 2017, 10:49:21 am » |
Hello. I want to order a 70 cm Lush. Thank you. Trond, you are famous now for the first Phasure webshop order. And I an see the money, that makes it even better.  Thank you for being the dare devil of The First. Best regards, Peter My pleasure, Peter. Can't wait to hear the Lush cable!
