April 01, 2025, 05:24:07 am *
Pages: 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16  All
Author Topic: The Lush  (Read 278229 times)
0 Members and 10 Guests are viewing this topic.
ciccio1112
« Reply #165 on: August 02, 2017, 06:56:33 pm »
Hi Peter We'll see ... after Clairixa I would like the new Lush by 1m. Thanks.
tory
« Reply #166 on: August 03, 2017, 01:56:43 am »
Hi Peter, would also like to order Lush 100cm. Thankyou
scottmac62
« Reply #167 on: August 03, 2017, 03:38:05 am »
Hi Peter, I would also like to order a 100cm Lush.  Not sure how the ordering process works.
mulberry bush
« Reply #168 on: August 03, 2017, 01:54:45 pm »
And another order for the 1m Lush please.
baconbrain
« Reply #169 on: August 03, 2017, 03:07:51 pm »
One meter for me please.
Gatoa
« Reply #170 on: August 03, 2017, 05:30:45 pm »
Please can you send me a Lush USB cable: 1,5m?
Kind regards
I'm lushed now and it's beautiful to listen more and more and more and more
« Reply #171 on: August 03, 2017, 05:33:47 pm »
I've just received my second Lush, for my office system. All I can say is that it has transformed the sound in here too - now totally natural and analogue-sounding.
It's crazy that a USB cable is capable of this yahoo
oscarnr
« Reply #172 on: August 03, 2017, 06:09:36 pm »
I would like to order a 150 cm Lush USB cable.
Thank you very much!
Oscar
PeterC
« Reply #173 on: August 03, 2017, 10:39:59 pm »
I would like to join the Lush queue with a 1.0m version please.
All the best,
Peter C
W10-14393 in boot camp on Mac Mini I7 Late 2012 with Smps replaced by UpTone JS2 lps and MMK linear fan controller (4 core; 8 cores hyperthread),16GB RAM, music on FireWire drive; no video connection, control via Ethernet to RDP on MacBookPro/ Engine#4 Adaptive Mode / Q1/-/3/4/5 = 14/-/1/1/1 / Q1Factor = 1 / Dev.Buffer = 4096 / ClockRes = 1ms / Memory = Straight Contiguous / Include Garbage Collect / SFS = 4  (max 150) / not Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / Scheme = Core 3-5 / Not Switch Processors during Playback = Off/ UnAttended / Always Copy to XX Drive / Keep LAN - Persist / WallPaper On / OSD On / Running Time Off / Minimize OS / XTweaks : Balanced Load = *43* / Nervous Rate = 1 / Cool when Idle = 1 / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = Stable / Custom Filter *High* 705600 -> Curious USB 0.8m -> UpTone ISORegen powered by Uptone LPS-1 ->Uptone solid link -> 24/768 Phasure NOS1a-> Audioquest Sky interlink -> Vandersteen M5-HP high pass filter ->Musical Fidelity A308CR Amp -> Vandersteen 3A Signature + dual 2Wq subs
mozes
« Reply #174 on: August 04, 2017, 07:04:06 am »
Hi Peter
Pls add me to the list with a 1m Lush USB cable
Rgs
Moussa
wisnon
« Reply #175 on: August 04, 2017, 01:01:06 pm »
I want to see what all the fuss is about.
Sign me up for a 2m cable!
Norman
« Reply #176 on: August 04, 2017, 01:04:25 pm »
Hey Norman, good to see you here. Which DAC will you be using the Lush with?
wisnon
« Reply #177 on: August 04, 2017, 01:07:41 pm »
Lampi Golden Gate, so I suppose with Amanero, I should get the UNpowered version, if there is such an option?
Mani, do you use any other USB gadgets with the LUSH?
« Reply #178 on: August 04, 2017, 01:16:58 pm »
Don't worry about whether your DAC needs a 5V connection or not. Just get a regular Lush (there is only one version anyway) and compare it to any other USB cable you care to try. I'm confident you'll be very happy with its sound in comparison to that of the others.
Well, there is a 'Phisolator' integrated into the NOS1 G3 DAC, so I suppose technically the answer is "yes". From what others have reported with other gadgets, I think it's a matter of just trying and seeing. But I'd go for a straight Lush connection to begin with.
wisnon
« Reply #179 on: August 04, 2017, 02:04:31 pm »
Thanks Mani...very clear.
I guess Peter will contact me via email to complete the transaction?
