Jiffi32
« Reply #150 on: July 26, 2017, 09:49:17 pm » |
Hi Peter, And yet another newbie from CA.  I'd also like to hear The Lush in my system. Can I request a .7m please Many thanks Jeff
kritpoon
« Reply #151 on: July 27, 2017, 02:13:04 pm » |
I have followed you here from CA also. I would like to try the LUSH, can you please provide me with ordering details for 1m? Thanks so much.
Krit.
feelingears
« Reply #152 on: July 27, 2017, 04:10:07 pm » |
Hello, Peter
Add one more person discovering you from CA... Please send me info for ordering a Lush USB cable as well. I understand you're overwhelmed so I'd like to get in line asap for my copy!
Please send me a 0.7m cable, thank you.
feelingears
« Reply #153 on: July 27, 2017, 04:32:27 pm » |
Thank you all again guys.
I like to notice that people should be observing the email address they used to sign up for this forum because that is where I send my emails to. I had the idea that a few people might be waiting on "something" and think that nothing happens.
Thanks and best regards, Peter
fmanheck
« Reply #154 on: July 27, 2017, 11:41:00 pm » |
I am a Phasure NOS1a and G3 music computer owner who does not post on the forum very often.
I would like to offer to anyone who is just now discovering Peter and XXhighend through the Lush USB cable my totally unsolicited yet extremely biased opinion.
If you are looking for SOTA sound quality, extraordinary support and service with cutting edge digital technology. You have come to the right place. Welcome
MACH lll PC 14/28 / RAM OS 10493/ 2.10 Phasure NOS1a G3 24/768 USB DAC KS mode -Adaptive/Device buffer -4096/DAC is 32bits 768khz/DAC needs -32bits/Phase Alignment - NO/Format Change - enable/ Decode HDCD ON/Processor Core Appointment 3-5/Player Prio LOW/Thread Prio Real Time/Clock Res 15ms/Xtweaks 64,1,1,0,1/ SFS 5.19 MAX 120/Include garbage collect ON/Copy to XXdrive by standard ON/Stop Desktop ON/Stop Remaining ON/Stop Wasapi ON/Keep LAN ON/Use remote desktop ON/Persist ON/OSD ON/Coverart show Wallpaper, show back, at attended, show mirror back/ Q1,3,4,5,xQ1-30,1,1,0,1/40/ Amp: Music Reference RM200 HC version / Speakers Omega HO Alnico Monitors with Audio Smile Super Tweeters Bass augmented by 2 GR Research OB subwoofers
« Reply #155 on: July 28, 2017, 06:33:08 am » |
If you are looking for SOTA sound quality, extraordinary support and service with cutting edge digital technology. You have come to the right place. Welcome Well said! Mani.
Dancause
« Reply #156 on: July 28, 2017, 08:12:53 am » |
Hi, please add me for a 70cm cable.
Thanks
Phil
« Reply #157 on: July 28, 2017, 08:15:08 am » |
Hi Phil,
Email coming up. Thank you ! Peter
Gatoa
« Reply #158 on: August 01, 2017, 09:03:47 am » |
Hi, Please can you send me a Lush USB cable: 1,5m?
Kind regards
Reiko2016
« Reply #159 on: August 01, 2017, 06:45:45 pm » |
I too am coming from CA and would like the .7 length please  Robin
hifial
« Reply #160 on: August 02, 2017, 07:41:37 am » |
Peter, I am interested in a 1 meter Lush USB cable. Could you please let me know what I need to do.
Thank you, Al.
Zorro
« Reply #161 on: August 02, 2017, 02:23:42 pm » |
I would like to place an order for one 0.7m cable. Could you also advise as to how much is the 1m cable? Thanks
Alan
« Reply #162 on: August 02, 2017, 03:15:13 pm » |
Hi there Alan,
The 70cm as well as the 100cm are 200 euros (ex shipping and VAT if you'd be liable to that). 150cm is 225 euros. You can also look in the first post if you want.
I will send you an email soon. Thank you ! Peter
sbilotta
« Reply #163 on: August 02, 2017, 03:20:46 pm » |
Hi Peter, I'm interested in a 0.7m Lush cable; could you let me know the full price (everything included) and where you are shipping from ? Many thanks Stefano
« Reply #164 on: August 02, 2017, 03:25:01 pm » |
Hi Stefano, Shipping is from the Netherlands. I will send you an email too.  Best regards, Peter
