« Reply #120 on: July 17, 2017, 08:13:00 am » |
I recently traded my T+A DAC8 DSD for a Pink Faun dac2.32. The Pink Faun does not (yet) have USB in but using the Wavelink USB --> spdif converter does give a very nice result, almost as good as i2s. USB chain consists of Jcat femto + hdplex lps, Intona industrial, Regen + Sonore lps. I wonder if the Lush can replace the Intona and Regen? Hi Kobus, Let me say that generally that won't work out. This is because each has its own objective/target. But, this is the general answer. Many other more specific answers are possible. Let me try a few : The cable changes the sound so much for less digital, that the JCat card doesn't help any more. The cable changes the sound so much for less digital, that the Regen could make it worse. I said could (and this is based upon about all of us in here that it does, as long as you can hear sufficiently deep into the music). The Intona got out of most systems with Phasure users, just because of the latest Operating System (Windows, W10 Build 14393.0). Is this related to the USB Cable ? well, actually Yes because if the cable is sufficiently transparent, you can hear better how the Intona "processes". Btw, same for the Regen. I'm afraid you just need to try. And in addition to that I would never sell any of those components if you're settled without all of them. You never know what the future brings. Same advice I have for everyone in here with the Clairixa cable, which is the technical better one. What does it do ? it lets you hear "digital" better. Hmm. But what if a next OS is inherently better on USB and the digital is not so much there at all ? well, once you'd observe that, you will always like to try the Clairixa again. Hope this helps you a little ! Peter
HenSch
« Reply #121 on: July 17, 2017, 08:26:37 am » |
please put me on your list for a 1m Lush cable.
Thanks a lot and keep it rolling, Henning
« Reply #122 on: July 17, 2017, 08:39:02 am » |
Thank you Henning. We'll glue the ends together so it will roll nicely. Plus it is something else for a change.  Peter
Kobus
« Reply #123 on: July 17, 2017, 09:30:28 pm » |
Thank you Peter,
I will just have to try and hear for myself. Will share my conclusion for the benefit of others that have similar USB chains. And indeed the Jcat femto could also be a victim.
Matt
« Reply #124 on: July 19, 2017, 08:46:09 pm » |
is there a certain length for the Lush where it sounds best? Thanks
Matt
« Reply #125 on: July 20, 2017, 06:27:32 am » |
Hi Matt,
Not that I know of. Everybody sofar has 70cm, 100cm or 150cm.
Kind regards, Peter
« Reply #126 on: July 20, 2017, 07:46:16 am » |
It was just pointed out to me that the chapter with the prices in the first post do not mention that this is excluding VAT. And indeed I always mention it but here it was forgotten. The line is there now.
AmusedToD
« Reply #127 on: July 20, 2017, 12:28:19 pm » |
I registered on this forum out of interest for the Lush USB cable. I am currently using the Curious USB.
Can I expect the Lush to sound better (more natural/musical) than the Curious? Are there any SQ differences between different lengths of the Lush cable?
Many thanks.
« Reply #128 on: July 20, 2017, 12:59:04 pm » |
Hi there, Can I expect the Lush to sound better (more natural/musical) than the Curious? Maybe you saw on CA that a first who also owns a Curious (BigalMc) received his Lush a couple of hours ago. I'd wait for his judgment ? I don't think there will be a real difference between the various lengths. What is out sofar is 70, 100 and 150 cm. I myself use 100cm (3ft). If you want to go ahead with it anyway then please send me an email (sales phasure com) with your address details. OK ? Best regards, Peter
« Reply #130 on: July 20, 2017, 02:35:30 pm » |
Well well ...  Thank you Matt. Regards, Peter
AmusedToD
« Reply #131 on: July 20, 2017, 03:21:09 pm » |
Thanks everyone, I saw the comment by hols on CA. I would appreciate a more thorough comparison though. I am especially interested in how the Lush behaves in the bass department.
« Reply #132 on: July 20, 2017, 03:36:27 pm » |
I am especially interested in how the Lush behaves in the bass department. Anyone who feels he has a good idea about the bass, please go ahead. I say this because AmusedToD (and also all of you) may think that I am going to answer this. But I am b(i)ased, so I stay quiet. Peter
Matt
« Reply #133 on: July 20, 2017, 04:42:42 pm » |
AFAIK, on CA most prefer the USPCB to the Curious. And there seems to be a tendency to prefer the Lush to the USPCB. So some sort of indirect comparison:-)
Matt
« Reply #134 on: July 20, 2017, 07:10:58 pm » |
I am especially interested in how the Lush behaves in the bass department.................................................
Anyone who feels he has a good idea about the bass, please go ahead. Well I am sure I mentioned this in a previous post but anyway here goes. I don't think that the previous posts do justice to just how good "lush" is particularly in the bass. I also mentioned that recently Peter made a significant change (or rather correction) to my system during his visit. The result of that correction was that to caused an "apparent" reduction in the impact of the bass. But as what I was hearing was wrong anyway that was no problem. So imagine my surprise when installing "Lush" seemed to bring all that bass back again. But even that is misleading because it is the quality of the bass that is really the most notable thing. I could go on about the tone and timbre of instruments now sounding much better and more natural but I won't cos that wasn't the question (  ) So simple answer is yes here bass is very much improved but so much more than that. Cheers Paul
