November 23, 2024, 06:36:03 am *
Author Topic: Initialize Tidal  (Read 16972 times)
Tore
« on: June 13, 2017, 11:06:31 am »
Sometimes when i`m ready to play a album from Tidal i get this message: Tidal could not be initialized (no connection)
It just happend with this album: Eric Bibb, Broker`s guitar
Tore
« Reply #1 on: June 13, 2017, 11:23:02 am »
Hey Tore,
Hmm ... I'd say that when you receive such a message that the Internet (!) connection is really not there. Is that possible ? So I really mean Internet as such (I think XXHighEnd uses Google.com to check for the presence of the Internet).
PS: it is Booker's Guitar and I don't see it on Tidal for The Netherlands (but have it anyway).
Tore
« Reply #2 on: June 13, 2017, 12:12:16 pm »
Hi Peter!
No problem with internet.
It just happens with  some album
Tore
« Reply #3 on: June 13, 2017, 12:42:57 pm »
Tore, if it happens again, can you give me a screenshot of the message so I can be sure what we are talking about ?
Tore
« Reply #4 on: June 13, 2017, 01:27:36 pm »
big enough ?
« Reply #5 on: June 13, 2017, 03:34:30 pm »
Yes big enough. And this message occurs in one occasion only : when www.google.com fails.
So maybe you can try that when it happens ?
Or are you saying that it always happens with one album (like the one from Eric Bibb which I can't test). If so, do you have another one ?
(but notice that I regard this impossible - if only that message is exactly the same (more of them exist in various forms)).
Tore
« Reply #6 on: June 13, 2017, 04:18:24 pm »
It just happens with some albums, not often.
I can play Eric Bibbs other albums.
I don`t remember other albums but i will report it when it happens again
Tore
« Reply #7 on: June 13, 2017, 05:41:59 pm »
Thanks.
What it is about for me is that I like to see some prove that it indeed is caused by an album, which I then must be able to test myself. But as said, it is impossible. The code looks something like this :
Test
  www.google.com
If Errored
  present message Tore shows
... and there is nothing else which can cause this message.
But indirectly everything can happen. So for a wild example : Tidal's response may cause Internet to fail temporarily on your side.
Oh, you may also tell what it actually is you do when this happens. So I started with a Search for that album (what else to do) but there I had to stop because I don't see the album. But maybe you are further with it (like Prepare) ?
Tore
« Reply #8 on: June 13, 2017, 07:21:00 pm »
When i press www.google.com all i OK. (on my music PC)
The album is Booker`s Guitar and the download with XX 2.07 looks OK (on my Music PC)
The message comes when i try to play it on my Audio PC
Tore
« Reply #9 on: June 14, 2017, 08:22:25 am »
... which does not have an internet connection (I assume).
So the message in itself is justified. But something must be not right with how the album has been "prepared". I am thinking of the Prepare having finished, but ending with a state which indicates it has not and now the Audio PC tries to Prepare it when you press Play, and it can't because of no Internet connection.
If you go to the highest level of the Album itself, which will be
\Booker's Guitar\
(there will be some more in that folder name like the date)
and you zip that folder (which will include the sub folders) and send it to me (e.g. with FileMail), I think I will be able to see what is wrong with it (wrong with how XXHighEnd deals with it).
Tore
« Reply #10 on: June 14, 2017, 05:32:17 pm »
Peter, i will be offshore for 14 days
Tore
« Reply #11 on: June 14, 2017, 05:35:52 pm »
OK Tore, we will pick it up later.
Tore
« Reply #12 on: July 02, 2017, 06:39:47 pm »
Hi Peter!
I have prepared all of the Eric Bibb album on Tidal and with many of them the preparation stops. When i look in the map of concern the map "Streams" is missing
Tore
« Last Edit: July 02, 2017, 07:46:54 pm by PeterSt » Logged
« Reply #13 on: July 08, 2017, 11:42:14 am »
Tore,
See below and the red bordered albums. 6 of them. Including the one with the thick yellow border, those are the ones I did not own already. They all were Prepared as should, and the yellow bordered one is "MP3" so rejected because of that.
Thus at least no problem with those ...
It isn't so that the ones which don't work out at your end, end up with yellow borders ?
Tore
« Reply #14 on: August 26, 2017, 05:52:26 pm »
the six ones that do not work out ends up with yellow borders (and is marked with "WAV" )
Tore
Page created in 0.114 seconds with 19 queries.
