March 31, 2025, 11:46:49 pm *
Author Topic: Linear Power supply for old XXHighEnd PC  (Read 26764 times)
« on: May 07, 2017, 04:50:15 pm »
Hi Peter, am currently saving my nickles and dimes for a Mach II XXHighEnd PC. In the meantime, any way your pc linear power supply could be fitted with my current mb- the one from the old XXHighend PC? If so what might you charge for that?  Happy
« Reply #1 on: May 07, 2017, 08:44:21 pm »
Hey there Brian,
Well, things are a leeeeettle bit different from what you might expect. prankster
Fairly soon after the Stealth was created and hit the roads, I also made a linear PSU especially for the old XXHighEnd PC. But I never even announced it. I also never tested it, but it will work ... (it is based on the Stealth's).
This one is far more complicated because it anticipates whatever unknown jobs and as you may be able to envision from below photo, it allows for a million configurations for 3 different voltages at the same time (like 3.3, 5 and 12) but with the storage capacitors configured as you wish. Well, "you", indeed because I am not going to try it.
These configurations are about how capacitors make the sound in such a situation - same as with the Stealth. But the LPSU and its configuration for the Stealth was determined by me, which is a project in itself where it is about capacitor arrangements. Anyway, the Stealth is just as is, while this one is configurable until you drop dead.
To give the idea : Stealth has only 13,600uF of capacitance (this is deliberately so low) while this one can hold 68,000uF for 12V alone which is how this part of the PSU will operate for the XXHighEnd PC. And 15A.
For ourselves we have a crazy document about what jumpers to put where for the configuration which is about all the numbers you see. Below you also see three drawings which are only for ourselves so we could make that document with jumper settings and to prove that no shortcuts occur / paths are used in combination which is not allowed. These are 3 drawings out of 12 we have for the various base combinations of how the voltages van be set up.
You know, you won't be inerested in this at all, but it is a kind of nice to show what happens all behind the scenes and that more projects never see daylight than those which do. This one actually did, but I never utilized it.
To come up with the price out of the blue is a bit difficult at the moment because it is mainly about the testing which never happened and the by now necessary explicit build of such an older PC. But I still have the parts for one, so this is doable. Of course the main thing is about whether it can hold (the power etc.) and whether the heat can be dissipated. But of all was calculated correctly, it can.
Think in the range of 400 - 450 euros. Maybe less.
Lastly, this board was very precisely created for exactly that cabinet of the old XXHighEnd PC. This includes that cut off corner, as it needs to be upright and then also the transformer can be neatly in there.
Call me crazy, OK ?
« Reply #2 on: May 08, 2017, 07:49:35 pm »
Wow Peter, cannot thank you enough for even considering this. Do you ever rest? Your work is amazing.
Anyway, I would be looking for the very simplest linear supply: one output for the mb of the old XXHighEnd PC as well as  proper outputs for the processor on the mb. I simply lack the know how to work with too many options/or choices and I would not be in a proper position to do testing.
No big deal if you are not interested. I agree it's important that folks get to see a bit of the work no one knows about!
« Reply #3 on: August 25, 2017, 03:09:33 pm »
bought this - HDPLEX 400W Hi-Fi DC-ATX Converter+HDPLEX 300W AC-DC combo at
https://www.hdplex.com/hdplex-400w-hi-fi-dc-atx-power-supply-16v-24v-wide-range-voltage-input.html
and the SQ improves ..... .  Happy Happy Happy Happy
Investment: appr. €161,00
The two HDD bays are not usable anymore, but SQ comes first.
« Reply #4 on: August 27, 2017, 03:59:16 am »
Thanks Joachim! Did this replace a Seasonic fanless  400w PS?
« Reply #5 on: August 27, 2017, 03:34:21 pm »
yes, it replaces the original PSU installed. The present operating temperatures of the both components are well below 50° C, and stable.
This combination may not be that sophisticated as Peters design shown above, but a LPSU (tested with my laptop two years ago) is an abolute must for an audiophile SQ. The outcome is amazing.
« Reply #6 on: August 27, 2017, 04:43:28 pm »
Hi Joachim,
I can't see everything on my phone (website of HD-PLEX is very distorted) but I don't think that is a linear power supply. So, the 300W part is a switching AC-DC converter.
Apologies if I appear to be wrong ...
« Reply #7 on: August 27, 2017, 06:35:58 pm »
After looking at the site I think Peter's right, that's why i asked if it replaced that Seasonic PS, cause that's the one I have. Perhaps, though I don't know for sure, the improved SQ your getting Joachim, comes from going to a fanless PS from the original PS with a fan. My Seasonic was quite an improvement over a high end Coursair that had a fan. I'm not sure that the one you've found would be an improvement over the fanless Seasonic. However, for about $800 Hyponex does sell a linear 400w PS, though its huge.
listening
« Reply #8 on: August 27, 2017, 09:34:38 pm »
I borrowed the card from a friend and tried the HDPLEX 400W Hi-Fi DC-ATX over my fanless Seasonic. The difference is audible and SQ improved. At the moment I'm using a Dell labtop adapter lying around to feed the card. I will test it too with a HAM Radio linear power supply from another friend.
Georg
-> SMSL SU-8 ES9038
-> 2x Neumann KH-120
« Reply #9 on: August 28, 2017, 08:40:53 am »
Peter is right. That "HDPLEX 300W AC-DC" is a switching unit.
The former PSU is a "Be quiet" brand with a fan.
The power comsumption of the first "XXH PC" is well under 60 Watts. I will start  "power consumption" tests with variuos operation conditions and will connect
a "160 Watt HDPlex LPSU" to the PC and compare the SQ during the day.
The combination with the "HDPLEX 300W AC-DC" presents a superior SQ to the former PSU at present.
Please accept my apologies for the false infomation concerning ..... !
« Reply #10 on: August 28, 2017, 09:56:51 pm »
No problem, always looking for that next tweak!  Happy
« Reply #11 on: August 29, 2017, 12:18:56 am »
following test results with
1.   HDPLEX 400W Hi-Fi DC-ATX Converter + HDPLEX 300W AC-DC
1A. The power consumption of the XXH PC (with a Xeon CPU) is appr. 60 Watts during normal operation.  72 Watts with a „heavy load“ during converting/storing files in „Unattended mode“ into RAM
1B. The surface temperature of both components was appr. 40°C
1C. The improvement of the SQ was very audible compared to the original assembly with the (cooling fan) "Bequiet" PSU
The ambient temperature during the tests/comparison was 26°C
2.   HDPLEX 400W Hi-Fi DC-ATX Converter + 160 Watt HDPlex LPSU
2A. The power consumption of the XXH PC (with a Xeon CPU) is now  appr. 79 Watts during normal operation.  91 Watts at the worst case.
2B. The surface temperature of the HDPLEX 400W Hi-Fi DC-ATX Converter was appr. 40°C,  and  at the 160 Watt HDPlex LPSU appr. 45°C
2C. The difference of the SQ between 1) and 2) is  very subtle, and I can’t say in what direction and it needs more listening.
Conclusion:
The 200watt HDPlex LPSU should work with the HDPLEX 400W Hi-Fi DC-ATX Converter and the components under item 1) are a bargain and should satisfy the owners of the first XXH PC with a XEON CPU.
Stanray
« Reply #12 on: August 29, 2017, 11:16:55 am »
Thank you, very interesting.
So is the conclusion justified that the benefits of a lpsu over a good fanless switching psu is not necessarily obvious? Of course depending on the pc processor, etc.?
I ask because when I built my audio pc, I invested in a "good" spsu (https://www.silentmaxx.de/leise-komponenten/netzteil-silentmaxxr-fanless-ii-500watt.html) and it seems not so obvious what the benefits will be of a lpsu.
Stanley
« Reply #13 on: August 29, 2017, 11:44:04 am »
Stanley
my only logical explanation from what I'm hearing here is that the "HDPLEX 400W Hi-Fi DC-ATX Converter" seems to have a major impact.
Two years ago I used a laptop and replaced  the SPSU with a LPSU, and the SQ  enhanced obviously, and that is not happening now.
Page created in 0.014 seconds with 19 queries.
