November 24, 2024, 01:40:15 am *
Author Topic: I can't get id of my TVC ... now what ?  (Read 5795 times)
leifchristensen
« on: February 18, 2008, 05:03:23 pm »
If I cannot skip my TVC because it´s a part of a complete pre-amp with LCR riaa in it; is it anything to gain by upgrading to 9u  ?
best
Leif
« Reply #1 on: February 18, 2008, 05:17:34 pm »
Hi Leif,
Well ... firstly stuff like 96/24 is supported in 9.0u-a1. But I guess you saw the Release Notes. Happy
Then, in theory yes. You should apply the sequence as explained in the Release Notes, ending with the TVC at Max volume, the volume now controlled by XX. Don't think this is worse for theories, because my "other" theories tell it is just better. BUT :
Chances are high that you find your TVC at max too noisy (and then because of the TVC). If that is so ... too bad.
But try it !
