« Reply #30 on: May 02, 2017, 05:59:19 pm » |
Gerard, that is the computer name you are showing there. The representative part you already filled with the IP address (this is good).
So, account name ... (XXHE)
Same message...
« Reply #31 on: May 02, 2017, 06:11:15 pm » |
Yes i/whe have done it  So now to the next..... And that is music from the laptop to the Audiopc.... Thanx
« Reply #32 on: May 02, 2017, 06:45:42 pm » |
« Reply #33 on: May 02, 2017, 08:53:55 pm » |
Everybody  I have it all working  Everything disconnected from my Audio pc and the laptop takes over  This sure was the most difficult thing i did on a pc.  Thank you all!!
zackthedog
« Reply #34 on: May 03, 2017, 05:28:03 am » |
Everybody  I have it all working  Everything disconnected from my Audio pc and the laptop takes over  This sure was the most difficult thing i did on a pc.  Thank you all!!  Congratulations!
« Reply #35 on: May 03, 2017, 07:50:14 am » |
Great. I'm sure you'll find an improvement in the SQ.
« Reply #36 on: May 07, 2017, 11:07:56 am » |
After 5 day's of been using this i do not have any problem regarding playback what so ever!! Not one sudden stop or tick....
« Reply #37 on: May 07, 2017, 02:32:32 pm » |
Glad you got it all working Gerard. It was a difficult job for me as well, way above my computer capacity. One thing I recently found was that unplugging the laptop from the mains and just running off it's battery gives a more organic sound. Not a huge difference but, for me, a significant difference. I just ordered a new battery for the laptop yesterday.
« Reply #38 on: May 07, 2017, 02:35:47 pm » |
Glad you got it all working Gerard. It was a difficult job for me as well, way above my computer capacity. One thing I recently found was that unplugging the laptop from the mains and just running off it's battery gives a more organic sound. Not a huge difference but, for me, a significant difference. I just ordered a new battery for the la ptop yesterday.
But the music plays from the xxpc?  How do you mean? Your audio pc is the laptop....
« Reply #39 on: May 07, 2017, 02:43:04 pm » |
No, the laptop is the server (4tb external hd with music files connected to laptop) which is connected to the audio pc (running XXHighend-no mouse keyboard, fans but running RAM-OS)through the LAN, which I believe is what you did too?
So running the laptop on battery power improves the sound coming from the audio pc. I guess there must be some small amount of noise that gets into the audio pc via the LAN connection. Running the laptop on battery power helps reduce that noise.
« Reply #40 on: May 07, 2017, 02:59:03 pm » |
I think it can be so that the Music Server PC spits on to the mains with its Switching Power Supply (probably a 19V brick in your case, Brian) and this noise gets into the Audio PC (which in your case also has a Switching Power Supply IIRC), but alas).
I have the Music Server PC in a sperate ring (with separate earth). I must say that I never tried it with a Linear Power Supply ...
« Reply #41 on: May 07, 2017, 03:46:16 pm » |
Ah ok..... But i have so many switching stuff......  Could you try that Peter? Would be easy
« Reply #42 on: September 03, 2018, 01:23:22 pm » |
Hello Peter,
Remember this post?
It has been a long time that i played music and yesterday i could not get it working.
I connected the laptop to the music pc and tried to make the connection by using the shortcut (MSTSC)
Two weeks ago i removed a lot of documents and foto's to make extra space on the laptop.
Could it be that i moved a certain file that i need to make it work?
Thanx Gerard
« Reply #43 on: September 03, 2018, 02:49:15 pm » |
Gerard, maybe your last activities on/for that laptop caused a Windows 10 update ? Or, that happened earlier already but you never tried RDC since ? Look here : CredSSP policy change - no RDP possible. Eh, good luck ! Regards, Peter
« Reply #44 on: September 03, 2018, 03:16:18 pm » |
Gerard, maybe your last activities on/for that laptop caused a Windows 10 update ? Or, that happened earlier already but you never tried RDC since ? Look here : CredSSP policy change - no RDP possible. Eh, good luck ! Regards, Peter Ah ok....  It is W7 SP1 Have to try it all again.
