April 01, 2025, 01:04:46 am *
Pages: 1 [2] 3  All
Author Topic: Help with Remote Control and music server.  (Read 64011 times)
« Reply #15 on: May 02, 2017, 11:48:33 am »
Hi Gerard,
Buy a Nuc or Barebone e.g. GIGABYTE BRIX GB-BACE-3150 fanless  € 150,-
Regards Johan
Thanx i will look into it... :-)
« Reply #16 on: May 02, 2017, 11:51:30 am »
Ok.....
Am i correct that a connection (LAN) between a laptop and the xxhighendpc wont work because off the fact that the XXHighend pc which is not connected to the internet has no IP adress?
So RDP wont work...
When i enter IPCONFIG in the XXpc there is no IP adress shown
Arjan
« Reply #17 on: May 02, 2017, 01:17:46 pm »
Hi Gerard,
You are correct. But you can determine a fixed ip address on the lan card and use that on both sides.
regards, Arjan
March, 2024 (2.11)
« Reply #18 on: May 02, 2017, 01:20:23 pm »
Hi Gerard,
regards, Arjan
Hey Arjan,
 And how can i do that?  scratching scratching
Arjan
« Reply #19 on: May 02, 2017, 01:38:47 pm »
Hi Gerard,
Try to google for setup static ip address windows 10.
e.g. https://www.supportrix.com/kb/how-to-set-a-static-or-fixed-ip-address-in-windows-10/
I use 192.168.1.2 as fixed IP address.
Hope this helps you further.
March, 2024 (2.11)
« Reply #20 on: May 02, 2017, 01:41:42 pm »
Ok will try that when i am home...
I can do that in 14393.0 in the XX pc?
Do not need to go to another version?
« Reply #21 on: May 02, 2017, 01:46:55 pm »
Ok.....
So RDP wont work...
Gerard, these things must be arranged for while being in Normal OS ...
« Reply #22 on: May 02, 2017, 01:51:41 pm »
I did that  Happy
Both pc are not connected to the internet.
I liked to try to make a connection from my laptop to the Audiopc.
Connected both with LAN kabel.
Going to try making a IP adres when i am home
« Reply #23 on: May 02, 2017, 03:13:30 pm »
Hi Gerard,
Control panel/Network & Internet/Network Connections/right click on Ethernet/ click properties from drop down menu/select internet protocol version4 (TCP/IPv4)/double click/select use only the following IP address/in IP address enter 192.168.1.1/press Tab which will give subnet mask 255.255.255.0/click ok.
Same process for the other PC or laptop except enter IP address as 192.168.1.2.
Now you've created static IP address for each PC.
Hope this helps.
« Reply #24 on: May 02, 2017, 05:04:15 pm »
Hello Peter,
Als Arvind Said i liked to go to the Network connections on the audio pc.
But the folder is empty.
Any idear?
« Reply #25 on: May 02, 2017, 05:18:57 pm »
Ah turned of in BIOS  Happy Happy Wink
« Reply #26 on: May 02, 2017, 05:34:32 pm »
Ok next  Wink
I got these message....
« Reply #27 on: May 02, 2017, 05:41:40 pm »
I don't know really, but I don't think the account name (gebruikersname) is RAM-OS. It will be XXHE.
Not easy to get the overview with the size of you pictures. I know I know, you want to show off with your camera ...
Happy Happy
« Reply #28 on: May 02, 2017, 05:52:59 pm »
Happy Happy
Sorry its easy with my tablet.....
But XXHE wont work...
« Reply #29 on: May 02, 2017, 05:55:44 pm »
Gerard, that is the computer name you are showing there. The representative part you already filled with the IP address (this is good).
So, account name ...
(XXHE)
Pages: 1 [2] 3  All
