April 01, 2025, 12:41:28 am *
Pages: [1] 2 3  All
Author Topic: Help with Remote Control and music server.  (Read 64008 times)
« on: May 01, 2017, 10:05:59 am »
So here it is  prankster
I am going to attempt making a remote control trough a music server..
I have 2? options..
Which should i choose?
« Reply #1 on: May 01, 2017, 10:57:17 am »
Hi Gerard,
In my opinion, you need to connect audio pc, music server & NAS to an Ethernet switch .
https://www.amazon.co.uk/NETGEAR-GS205-100UKS-Gigabit-Ethernet-Desktop/dp/B00AYRZYG4/ref=sr_1_4?ie=UTF8&qid=1493628581&sr=8-4&keywords=Ethernet+hub
Create static IP address for all 3, XXHE pc, music server & NAS.
RDP connection between XXHE PC & music server.
Then connect music server & remote tablet over wifi, maybe Bluetooth but I'm not sure.
« Reply #2 on: May 01, 2017, 11:01:20 am »
Hi Gerard,
ok thanx....
So 1 cable from meterkast to the place where i have the XX pc and Music server... I have such a switch laying around somewhere so i can use that....
Thanx
« Reply #3 on: May 01, 2017, 11:46:30 am »
Gerard, my strong recommendation is to go for your option 2. This will totally isolate your audio PC from the internet. You will then need to set up an RDC connection from the server to the audio PC - simple to do. And then connect to the server remotely in whichever way works for you.
I used to use a Synology NAS and switched to a server PC a while ago. It's a much neater solution IMO. But one thing I found was that everything works 'better' if both the server and audio PC use Win10.
Sorry, don't have time to go further right now, but ask any questions and I'll answer in a short while.
« Reply #4 on: May 01, 2017, 12:29:27 pm »
Hi Gerard,
To your question...yes.
Referring to Mani's suggestion, your music server would need to have 2 lan ports. One to connect NAS & the other to connect to audio pc. If I have understood Mani's suggestion correctly.
« Reply #5 on: May 01, 2017, 02:20:23 pm »
Mani and Arvind,
Thank you....
So both W10.....  good
But i was thinking if i do it like this.... I do not need internet???
This for my situation would be ideal for now....
This will work????
« Reply #6 on: May 01, 2017, 03:40:07 pm »
Hi Gerard,
If you're still considering a NAS for music data storage, that would need to be connected to the music server via Lan.
« Reply #7 on: May 01, 2017, 04:02:08 pm »
Hi Arvind,
With again the notice that I don't like a NAS etc. etc. and don't own one, are you sure about this :
Because I think that can not work because of two reasons :
1. You can not share the NAS to a PC and another PC next using the data of the NAS via again a share the Music Server PC has (the NAS can not be shared again);
2. It *is* possible when the 2x LAN connections are bridged (via the both Network Adapters), but now the Audio PC is connected to the Internet.
Of course there's more do's and don't's like Gerard implying (?) that he won't be connected to the Internet at all. This allows for #2 above.
Gerard, I need to stress that you are working (or seem to be working) on a setup which disallows Internet all together, which is fine. But it also cuts you from (e.g. ?) Tidal and for some future you may want that.
So I say that the Music Server PC should be connected to the Internet.
For Arvind (and others) : no NAS allows you to utilize Tidal via XXHighEnd or IOW that does require a PC as such. And now if you put everything together (what I said above), the NAS is redundant.
Only when you allow the Audio PC to connect to the Internet, the whole is a different story. But let that be for now because it is only confusing and I don't think anyone would really want that.
Sorry to interfere !
« Reply #8 on: May 01, 2017, 04:44:03 pm »
Hi Gerard,
With the above connection I can access the NAS from both audio pc (via RDP) as well as music server. Pls note I do not have monitor, keyboard or mouse connected to the audio pc. I operate the XXHE pc via music server (laptop) using RDP.
My music server is connected to the internet via wifi. But no internet connection to the audio pc.
I hope this answers all the questions. Otherwise shoot some more.
« Reply #9 on: May 01, 2017, 05:16:52 pm »
Hey Arvind,
I misread you here and interpreted it as "via LAN cable". Literally though you said "network and thus via switch/router".
I apologise !
« Reply #10 on: May 01, 2017, 06:35:10 pm »
Ok i am going to skip the idear with the NAS for now...
I have a second pc which i do not use and can make it a music server with one 8 TB HDD...
« Reply #11 on: May 01, 2017, 07:00:23 pm »
Good choice. I'd recommend that you get hold of a second HDD and keep a backup of your 8TB HDD on the server also. The HDDs in my server all spin down after literally a few seconds of inactivity and remain that way until accessed again. The Win10 OS is on a separate SSD. When using XX in Unattended and 'copy to XX file', all the files are transferred to RAM in the audio PC and the HDDs in the server spin down. I reckon it's a really neat solution, and should increase the longevity of the HDDs.
« Reply #12 on: May 01, 2017, 08:48:55 pm »
Ah that sounds good... That's what i did not like in this setup... In my case the Music server is in the same dresser as my XXhighend pc.
Making the XX pc quit as possible but a music server which still makes noise  wacko
 thankyou
« Reply #13 on: May 02, 2017, 10:01:11 am »
Try a laptop as music server. Won't make noise.
« Reply #14 on: May 02, 2017, 11:14:58 am »
Hi Gerard,
Buy a Nuc or Barebone e.g. GIGABYTE BRIX GB-BACE-3150 fanless  € 150,-
Regards Johan
Pages: [1] 2 3  All
