« Reply #45 on: June 06, 2017, 07:43:55 am » |
Thank you Arvind. The only area the G3 lacks is a bit shy in the bass section. Fortunately with the Orelo's at my disposal this can be easily rectified. This is a bit hard to believe (the first part of it  ). I mean, if you judge this relative to the "old" NOS1a ... I rather have the idea that you possibly have to set more gain in the Orelo than the theoretical 6dB (you will understand what I am talking about). I mean, you can't compare with the old situation, right ? Best regards and enjoy ! Peter
« Reply #46 on: June 06, 2017, 07:47:59 am » |
Arvind, I forgot ... Not sure whether I mentioned it somewhere, but you can try the SFS of 0.90 and see what happens to your bass. With that I have Q3,4,5=1.
« Reply #47 on: June 06, 2017, 09:47:05 am » |
Sure will try out the SFS & Q settings.
It's possible based on Bert's suggestion I had increased the gain in the Hypex by 6dB. Maybe that was inadequate as I had to increase further 0.8dB. So you're right it's not apple to apple comparison.
« Reply #48 on: June 06, 2017, 03:22:07 pm » |
With SFS 0.9 & Q345=1, there isn't a significant difference in the bass. If at all it's slightly softer.
« Reply #49 on: June 09, 2017, 01:07:50 pm » |
Hello Peter, Bloody hell, this is the ultimate music replay component now.  Lots of more unheard details, and the music from „ Weather Report“ is unbelievable now. The upgrade to the NOS1 G3 is a masterpiece and „an absolute must have it“.  Peter -> thanx Joachim
« Reply #50 on: June 09, 2017, 01:33:42 pm » |
Hi Joachim - Yeah, nice eh ?
Thank you for your post and kind regards, Peter
esimms86
« Reply #51 on: July 23, 2017, 02:03:58 pm » |
I second Joachim's comments. The upgrade makes an already phenomenal DAC that much better. Ridiculously cheap at the price and a no brainer decision from a buyer's standpoint. Just add in the Lush with no increase in shipping and you're all set. Together, the G3 upgrade and the Lush, coming with the usual "built in" support from Peter, are the best deal in Audio.
2010 mac mini running Windows 7 Professional N 64bit *SP1* and XXHE on SSD in Boot camp mode, mac os x Snow Leopard with Audirvana Plus also on SSD, music on separate 2 Tb firewire La Cie HD / 8 Gb RAM/ Engine#4 *Adaptive Mode* / Q1/2/3/4/5 = *30*/0/0/0/0 (Dev.Buffer = *4096*) / ClockRes = *15ms* / Straight Contiguous / SFS = 170 / not Invert / Playerprio = Low / ThreadPrio = Real Time / Scheme = 3/ *Minimize OS = On* / 24/768 Phasure/Is Phasure NOS1/ NOS1 async USB DAC, Driver v1.0.2 -> Marantz PM KI Pearl amplifier ->Gallo Strada/Gallo TR3 subwoofer
« Reply #52 on: July 23, 2017, 04:29:53 pm » |
Thank you Esau.
Btw, at some stage I think I'll merges the two topics about the G3 upgrade.
Thank you for your kind words, Peter
briefremarks
« Reply #53 on: September 23, 2017, 08:31:12 pm » |
UPGRADE TO G3 NOW!!!
I can only add to what has already been said. This is an amazing upgrade. Extraordinary detail and realism, astonishing dynamics, everything is balanced.
I noticed lyrics to lines used to be indistinct. All kinds of new ambient detail in live recordings, extreme reality in tone of instruments, attack, decay.
Exceeded all my expectations.
Truly magical Peter!!
« Reply #54 on: September 24, 2017, 06:26:44 pm » |
Btw, at some stage I think I'll merge the two topics about the G3 upgrade. I now just did that. Peter
Rmalits
« Reply #55 on: October 13, 2017, 11:21:48 am » |
YES, 3G IS AN AMAZING UPGRADE!!!
I was not at home during the summer, so I had a two month break without listening to this high level of SQ. Coming back home I installed my 3G upgraded NOS1-a right a way. And the first impression was WOW!!! I never before had these great basses. Soon I relaized all the incredible improvements of SQ in varous aspects: higher precision, clearer soundstage, better basses, all together a significant fuller body of sound with higher precesion. Just great.
There is one point, which maybe was not mentioned before (I didn't read all the post though): As I reported some months ago, I had kind of a instability of sound when running the NOS1-a for a longer time. After about 5 hours or so, the sound became imprecise and after a day or even more "smearing". So I had to switch off and on my NOS1-a after a couple of hours to get the good SQ back again.
With the 3G UPGRADE THIS BEHAVIOUR IS GONE! There is no need to switch it off and on frequently. It seems to be just the opposite: After switching off and on, the NOS1-a 3G need some minutes to deliver again its best.
3G IS A MUST!!!
Richard
« Reply #56 on: October 13, 2017, 12:20:12 pm » |
Haha, thank you Richard !
Kind regards, Peter
Stanray
« Reply #57 on: October 13, 2017, 01:32:51 pm » |
I was thinking how to write down my experiences with the G3-upgrade, but when I read Richard’s post above there’s no need to. I completely agree with his words and maybe add one thing. Some albums kind of sound “new” or different compared to before. I had to check if I played the right album. It’s like the emphasis on some instruments is different that what I was used to. But in a very convincing way (I hope you understand what I mean  ). Great job Peter! Stanley
« Reply #58 on: October 13, 2017, 03:49:03 pm » |
I had to check if I played the right album. It’s like the emphasis on some instruments is different that what I was used to. Hi Stanley, I guess that you finally ran into such a situation which I have been telling about a dozen times : you're quite sure you never heard the album before ("in this version"). Quite amazing eh ? So yes, I fully understand what you mean and assumed the change is for the better, you can nicely revisit all of your favourite albums the upcoming two years, waiting for the next upgrade. Haha. Thank you and have fun ! Peter
jabbr
« Reply #59 on: October 20, 2017, 01:33:56 am » |
Ok so Peter get working  I'm without NOS1a in meantime -- wow it got there quickly from Cincinnati! I'm wondering if absence makes the heart grow fonder? My Lush is flapping in the breeze. Jonathan
XXHE on ASRock Q1900M, Intel x520 singlemode fiber -> NOS1a -> FirstWatt J2 -> Senn HD800, AKG 712, The Hornshoppe
