April 02, 2025, 09:44:34 am *
Author Topic: 32 bit OS and 2.07 Install Issue  (Read 4543 times)
« on: March 09, 2017, 05:55:53 am »
It appears that for the 32 bit Operating System there's a bug in the install procedure and an "OCX" related error message will appear and the install can not continue.
For the 32 bit OS, running the Setup.exe which resides in the folder where XXHighEnd has been put to, will solve this issue.
Notice that it takes some longer before this Setup seems to respond; wait a while and you will see it just goes.
After this, XXHighEnd.exe can be started for the normal Install Procedure and all should be fine.
