April 01, 2025, 12:33:25 am *
Pages: 1 2 3 4 [5]  All
Author Topic: NOS1a and HQPlayer on Win 10  (Read 78679 times)
« Reply #60 on: August 07, 2017, 07:34:16 pm »
Mani, thank you for your help !
Kravi4ka
« Reply #61 on: February 17, 2018, 10:27:35 pm »
Hm,
I honestly hate to bring this up but I read everything very carefully, did all I read here, several times and I cannot get the HQplayer to make a single sound through the NOS1a G3...
I did a fresh driver installation on a computer that doesn't have an XXhighend player installed(managed to do so after I switched off "signed off" in Windowds 10), then I went to Sounds and found the Phasure 1.0.4 WDM driver 4.0, disabled all enhancements. Even set it up as default once.
Then I run Control board, chose 384000 and then 352.K and hit apply. Chose 12ms for the USB buffer.
Then went to HQplayer setup and checked all the boxes as per Mani's instructions.
When I load a file by drag and drop on HQP and press play I get a window that as below the progress bar and a blue line goes from left to right and sometimes back but I never hear sound and the progress bar never moves... Did it a million times, the log files sometimes says that there is not enough space to perform the task, sometimes it says it could not push it to the FIFO.
One thing that I find weird is that when I try to add a file through HQP library it never recognizes music files.
Any other ideas I could try? That is with both up and down positions of Switch#5...
Decided to ask, Mani is probably very tired from my emails.
« Reply #62 on: February 18, 2018, 08:35:59 am »
Hi there Mr without name ...
First things first : Install the Driver properly. I assumed that happened (Unsigned Drivers must be allowed etc.).
Then actually first off, if you select in the NOS1 Control Panel for Device "Stereo Reduced" (and not the default Multi Channel 4.0) *and* you set Sw#5 in the Up position, you have a regular DAC for its interfacing means. Nothing strange, nothing odd. IOW, your first task is to get HQPlayer working in that normal mode, and this is already challenge enough (which I really can't help of course).
And be in Normal OS all the time.
And have the UAC ENabled ! (set that via XXHighEnd, via RightClick on the Stop button).
And disengage that two wire thing in HQPlayer.
Let us know when you've got this working. Or when you can't. Happy
