November 23, 2024, 05:59:00 am *
Author Topic: 2.07 won't launch  (Read 20688 times)
« Reply #15 on: January 12, 2017, 11:43:55 am »
Mani,
OK. What about the rights to that folder or all the files ? Something should be wrong with it ...
(for example, when you first copy all to a CD and then to the hdd, something like this can happen)
« Reply #16 on: January 12, 2017, 12:17:25 pm »
All I did was extract the 2.07 upgrade patch into the 2.0x folder where 2.06a was sitting, and working perfectly. I've just checked all the rights to this folder and everything seems OK.
Anyway, I have just created a new 2.06a folder and extracted 2.06 and then the 2.06a patch to it. 2.06a seems to be working fine. I will extract the 2.07 patch over this and see what happens.
« Reply #17 on: January 12, 2017, 12:51:36 pm »
OK, there is something strange going on...
I have managed to get 2.07 working on my music server. BUT... as soon as I close it, XXHighEnd.exe gets replaced by the previous 2.06a version. I'll try to replicate this and take a few screen shots.
« Reply #18 on: January 12, 2017, 01:03:54 pm »
I think I already know what is going on ... your super duper non-NTFS system !
« Reply #19 on: January 12, 2017, 01:04:40 pm »
Ahhhhh... All solved.
The problem seems to have been using a screen shortcut for XX, with 'run as administrator' checked, which is what I've always done for software players. Everything works fine if this is not checked.
« Reply #20 on: January 12, 2017, 01:05:44 pm »
Nah, the c: drive is a regular drive. Anyway, see above...
« Reply #21 on: January 12, 2017, 01:11:55 pm »
Everything does seem to work now, but I thought I'd share these just in case there is something untoward still going on.
« Reply #22 on: January 12, 2017, 01:18:08 pm »
Hey Mani,
Yep, that explicitly does NOT work. Odd eh ?
But apart from that we may all  recall that from the very early XXHighEnd days (at very first we had to run as Administrator, which soon after changed in NOT doing so), I tried with regard to the UAC stuff the other day and this still is not possible. I forgot a bit why and did not really pay attention to that because my focus was on the UAC stuff (of which I am glad I could get that to run now).
Any idea what -in the end- cause that rename to fail ? is it in the same realm (somehow) ?
« Reply #23 on: January 12, 2017, 01:31:17 pm »
OK, my excuse is that I still feel jet-lagged from coming back from holiday...
I now realise that xxhighend.exe is not being reverted back to the 2.06a version at all. It just so happens that the 2.06a version was dated 12/(can't remember month)/16. The 2.07 version is dated 23/12/16. So when I saw 12/x/x in the date, I thought it was going back to 2.06a. But actually, it says 12/1/17. I never realised xxhighend.exe was 'updated' after each use.
Sorry for any confusion.
