November 23, 2024, 06:13:53 pm *
Pages: 1 2 3 [4]  All
Author Topic: How .9u Sounds  (Read 65408 times)
edward
« Reply #45 on: February 20, 2008, 01:26:51 am »
Indeed I used 2 -3 songs in 16/44.1 format and with these songs I went through all settings from DAC is 16/44.1 to DAC is 32/192 with DAC needs 32 bits.
And for all settings I was able to hear my 16/44.1 songs with no errors.
HOLD THE HORSES!!
If I try to play a 16/44.1 song and change my DAC to "needs 32bits" then I get a whole slew of messages:
-UNSUPPORTED FORMAT
-2/32/44100/352800/8
-Device (currently) does not support/allow Exclusive Use. It will not be bit perfect!
-Error number :1
-Device cannot be allocated in pre-check state
Peter, you told me "upsampling from 44.1/16 to 96/24 is not supported yet".
Then you also said "Strangely enough I can just Double to 88.2/24".
If I play 16/44.1 songs, I can no longer use "double" or "upsample", no matter what my "DAC needs" settings are.
I thought my situation was the "norm", so how can Andrey be playing 16/44.1 songs with DAC needs 32 bits??
April 19, 2008
« Reply #46 on: February 20, 2008, 09:46:03 am »
Well, I said that a little differently of course :
Strangely enough I can just Double to 88.2/24 (which I have working here now yes)
So *I* have that, you don't. Happy (yet)
That you cannot Double or Upsample at all, while before you obviously could, is the strange matter of ... well, I just thought of something ... !
Hehehe, I now realize that before, I set the appropriate settings to ask the DAC for its possibilities ... well, AFTER I ask that to the DAC (driver). This was a kind of quick-tweak to get that running a year ago. Today ... I do that as should, so I set it before asking the DAC. And there it gets rejected now ...
So it's my guess if I move *all* the settings to *after* asking the DAC, and let that asking be dummy 44.1/16, it would work.
I know, I'm talking to myself here, but I guess I just found the tweak to get things going while now they won't because of "bugs" in that part of Vista.
What I will do as well, is create an enumeration of what "your" soundcard will accept for playing. Just all the combinations it('s driver) doesn't reject, and report that. Can save you tons of time.
« Reply #47 on: February 20, 2008, 05:20:59 pm »
I am playing regular 16/44.1 cd ripped files.
What I was saying refers to settings area, "DAC is 24 bits 192.0 KHz" combobox not the track formats.
I did this too.... It play's but before playing this error come's up.... what does it mean?
Grtz.... Gerard...... Happy
« Reply #48 on: February 20, 2008, 05:25:30 pm »
That you just changed the setting from more than 16 bits to 16 bits, while the system auto-unticks the either 24 or 32 which was there (the "auto" is not much clear and will change in the next version).
« Reply #49 on: February 20, 2008, 10:33:19 pm »
This is what you said in the realease notes. What do you mean by that? Meaning the word before... Do you refer to a previous model? Do you mean by this that the music is only different when you play around the 30/24 db? (Less than 0 db)
Or am i totally wrong on this one..... dntknw Happy
Expectations on changed sound quality : totally different from before.
But if you don't want that, keep everything connected as usual, and set the Volume Slider (topmost) to -0dB. Sound will be the same as before with 16bit files.
« Reply #50 on: February 20, 2008, 11:33:29 pm »
Yes. Which appears not to be true. E.g. : Version 0.9U feedback ...
« Reply #51 on: February 23, 2008, 11:48:20 am »
Ok, this all appears to be true ... With my regards to MS ...
My "analisys" functionality is finished now, and I managed to get the real merits of what Exclusive can and cannot do. That is, this function does not report anything that -as far as I can see- is not justified, but it still *may* be so that it doesn't report possibilities of the Soundcard/DAC while it actually has them. In that case there's nothing left to do that I can think of at this moment. But first let's see how (in)consistent this reporting now is opposed to what "you" think your Soundcard/DAC is capable of.
I have to finish up the code a bit, and I guess within a few hours a 0.9u-1 will be up.
« Reply #52 on: February 23, 2008, 05:04:25 pm »
Upsampling *and* using the Digital Volume Control should really not be applied together !
Do we have to leave it at 0db?
« Reply #53 on: February 23, 2008, 05:20:45 pm »
If you Upsample, yes (0.9u-1). But maybe I don't understand the question, because what you ask for is in the Release Notes, and you can only ask because it's in there ?? haha
« Reply #54 on: February 23, 2008, 05:23:09 pm »
Btw, for UpSample this aplies. With Double you can do as you like.
« Reply #55 on: February 23, 2008, 07:21:24 pm »
Peter, All,
32 (most often) is working here... 24 (untested) still gives the error "inconsistent" The Not Supported thing becomes less depending how high i set the latency of my soundcart.
I have got Double working.... Sounds different.... But i cannot point out what it is at the moment.
upsampling i can check... But i don't know if it works... but the sound that come's from it somehow i don't like...
The higher i set the latency the less i can play and error's come up... when i set it to 88.2 i can play Double.
« Reply #56 on: February 23, 2008, 07:43:45 pm »
The Not Supported thing become's less depending how high i set the latency of my soundcart.
Can you rephrase please Gerard ?
« Reply #57 on: February 23, 2008, 07:54:52 pm »
Well as you can see http://www.phasure.com/index.php?topic=381.msg2609#msg2609  i can set it from 44.1 to 192... When i set it to 44.1 than pic 1/88.2 gives pic 2/192 gives pic 3.
(pic 1)
Start Audio Device Analysis Exclusive Mode support
03ECFD38
    Supported : 2|16|44100|176400|4
    Supported : 2|24|44100|264600|6
    Supported : 2|32|44100|352800|8
Not supported : 2|16|48000|192000|4
Not supported : 2|24|48000|288000|6
Not supported : 2|32|48000|384000|8
Not supported : 2|16|88200|352800|4
Not supported : 2|24|88200|529200|6
Not supported : 2|32|88200|705600|8
Not supported : 2|16|96000|384000|4
Not supported : 2|24|96000|576000|6
Not supported : 2|32|96000|768000|8
Not supported : 2|16|176400|705600|4
Not supported : 2|24|176400|1058400|6
Not supported : 2|32|176400|1411200|8
Not supported : 2|16|192000|768000|4
Not supported : 2|24|192000|1152000|6
Not supported : 2|32|192000|1536000|8
(pic 2 )
03ECFD38
    Supported : 2|16|48000|192000|4
    Supported : 2|24|48000|288000|6
    Supported : 2|32|48000|384000|8
    Supported : 2|16|88200|352800|4
    Supported : 2|24|88200|529200|6
    Supported : 2|32|88200|705600|8
(pic 3)
03EDFD38
    Supported : 2|16|96000|384000|4
    Supported : 2|24|96000|576000|6
    Supported : 2|32|96000|768000|8
    Supported : 2|16|176400|705600|4
    Supported : 2|24|176400|1058400|6
    Supported : 2|32|176400|1411200|8
    Supported : 2|16|192000|768000|4
    Supported : 2|24|192000|1152000|6
    Supported : 2|32|192000|1536000|8
« Reply #58 on: February 23, 2008, 08:30:35 pm »
Ok, I understand. This is not related to "latency" though.
Here too (referring to a post somewhere else), I'd ignore the 24 bit possibilities. They are not real.
Page created in 0.121 seconds with 19 queries.
