November 23, 2024, 08:43:38 pm *
Pages: 1 2 [3] 4  All
Author Topic: How .9u Sounds  (Read 65431 times)
0 Members and 16 Guests are viewing this topic.
andy74
« Reply #30 on: February 19, 2008, 11:48:22 am »
invert is left unchecked all the time.
Thanks for the new version for me.
Actually it is strange that we (Russ and I) hear the difference where you did not intend to change anything.
Andrey
« Reply #31 on: February 19, 2008, 12:42:32 pm »
Hi All smile
to recap my setup here, I have a Juli@ card ( 48 samples buffer ) feeding via coax into my Sony pre-processor ( TA-E9000ES ). The Sony pre-pro is essentially digital throughout and as such I would imagine it benefits well from a higher sample rate than standard 16/44.1K.
My initial listening to ver 'U' was with Vol at 0dB and no change to the 'DAC' setting of 16/44.1k. Something had definately changed for the better in my perception though compared to ver 'T', but I'm not naive enough to think that it wasn't a placebo effect in anticipation of the new version. One's listening perception's change from day to day and your mood so it was pleasing to discover that the next days listening still brought forth the improvement I had initially discovered.
Further experiments today had me playing with the Volume control on XXHE in conjunction with the Volume control on the Sony. I normally have the Sony set at -30dB readout, and that gives me an inroom volume of about 80 to 85dB peaks. I dropped the XXHE vol to -30dB and maximised the Sony vol to 0dB. Overall volume in room was still the same but there was now a slight background 'hiss'. Juggling the two controls, I have settled on -12dB on XXHE and -18dB on the Sony. This combination is very pleasing ! I should also add that I have set the 'DAC' setting to 24/96K ( which is what the Sony is capable of handling ) even though the Juli@ will output 24/192. I also found that dropping Q1 down to -2 helped tighten up the soundstage a tad.
So, for those without external DAC's, you can still experiment with the setting of each volume control, and may well find benefit's in that route.
Happy listening folks smile
« Reply #32 on: February 19, 2008, 01:09:54 pm »
Thank you for clarifying Russ !
Well, since the word is out anyway ... for those who don't want to get rid of their pre-amps for their own reasons *or* for those who just want to experiment ...
The whatever it is I "applied" (hehe) causes that each combination of volume of pre-amp vs. XX (with the same totalling output level I mean) will create another sound. So, there you have it. Now you can get lost in combinations. wackowackowacko
Although with Russ it probably is (and initially was) about a proper balance between (pre)amplifier noise and using the digital volume in combination with a wanted output level, the both means of volume apply their own signature to the sound;
So far I "gave" you the opportunity to go over the hill and do it digital only, for now assuming that would be good and the best. But this is not necessarily true !
I never tried it but know I should. Otoh, I really like to get rid of the pre-amp (TVC) which is in the way for SQ reasons in general.
Ok, on to the next step. Happy
andy74
« Reply #33 on: February 19, 2008, 01:20:01 pm »
It has just occurred to me that in both of my setups I have a single core CPU so no scheme is applied.
Andrey
« Reply #34 on: February 19, 2008, 02:18:48 pm »
I am not sure but it even looks like there is more seperation between left and right.... smile
andy74
« Reply #35 on: February 19, 2008, 07:55:57 pm »
Hi Peter/Russ/All,
I can join Russ' nirvana now!!!
I tried them all from 16/44.1 upto 32/whatever.
And that bad feeling stayed fro all of them untill I came to 24/44.1(192) and voila it sounds without any discomfort and still better than t-7.
I am using 0dB. Don't want to try to bypass preamp for now. Although I have the option on my integrated amp.
But the idea is it sounds good again.
Edit: works only with 32 bit. and with 24 fails
Edit: In the "DAC needs" section
Andrey
PS: Will try to play with my el cheapo card tomorrow. But as I can remeber now it does not support other than 16/44.1 and the bad feeling is there.
edward
« Reply #36 on: February 19, 2008, 08:43:28 pm »
I'm a little confused by what you are saying here, and I was just wondering if you could clarify - are you making these comparisons with the same song? I mean, you can't be, right? You can only play 16/44 when 24 and 32 are unchecked in the "DAC needs" section, right? And conversely if "DAC needs" is set to 32bits, then are you playing a 24/96 track?
April 19, 2008
edward
« Reply #37 on: February 19, 2008, 08:46:52 pm »
I'll try to get you something which is for 44.1/16 (ouput !) the most similar to 0.9t.
No, please don't take a step backward. I don't want my 16/44.1 output to sound like 0.9t.
Am I misunderstanding what you are saying here?
April 19, 2008
andy74
« Reply #38 on: February 19, 2008, 09:20:41 pm »
I am playing regular 16/44.1 cd ripped files.
What I was saying refers to settings area, "DAC is 24 bits 192.0 KHz" combobox not the track formats.
« Reply #39 on: February 19, 2008, 09:32:28 pm »
Ok, I'm lost.
too much ! too much ! too much !
Later ...
(I already changed the program, but I can put things back again, no problem Happy)
andy74
« Reply #40 on: February 19, 2008, 09:37:20 pm »
For those with 16/44.1 only cards, ok namely for me (my other setup), please make that special version, which you already changed.
Thanks
Andrey
« Reply #41 on: February 19, 2008, 09:50:33 pm »
Not so fast ... Happy
First I want to understand what happened whith your other setup. As far as I can tell Edward must be right ...
dinamanu
« Reply #42 on: February 19, 2008, 09:52:46 pm »
I vote for XX volume  Happy
Vistabusiness,hw all DIY: PC>AYAII 1541UsbDac>Truepath>Ellam
andy74
« Reply #43 on: February 19, 2008, 10:00:54 pm »
Indeed I used 2 -3 songs in 16/44.1 format and with these songs I went through all settings from DAC is 16/44.1 to DAC is 32/192 with DAC needs 32 bits.
And for all settings I was able to hear my 16/44.1 songs with no errors.
Now regarding that bad feeling of mine: All settings except for 24/* gave me taht bad feeling. But 24/* is just perfect.
Does this help?
« Reply #44 on: February 19, 2008, 10:19:25 pm »
Clear Andrey.
