November 23, 2024, 04:49:10 am *
Author Topic: 2.07 installation and activation  (Read 21511 times)
fralippo
« Reply #15 on: January 03, 2017, 04:09:25 pm »
I see. So you mean that by default, at initial installation, memory is ALREADY set to "Straight Contiguous"???
I can't remember that... but I'd bet that I changed to SC manually later.
« Reply #16 on: January 03, 2017, 04:30:00 pm »
Uhm ... please tell me, did you get that popup to reboot right after the first time you started XXHighEnd, or later ? (see your post with the 3 photos, which suggests that you got it righyt away).
I like you to win the bet but I'd rather win it myself because I just put a small strange addition to the download which I don't like much (so if this is moot I want to remove it again).
« Reply #17 on: January 03, 2017, 04:39:37 pm »
OK, I just thopught of a way to check what happened for real myself (with that Memory setting) and it is just set to Mixed.
This means that you faked the photo sequence. Happy
Am I right ?
This could have happened too :
1. fralippo installs XXHighEnd on a fresh W10.
2. All is fine. He now changes the Memory setting.
3. A message to reboot occurs as shown in the first photo.
4. fralippo thinks WTF ! and re-installs XXHighEnd.
5. At the first startup he sees again this message and makes a photo of it.
6. After that and a reboot the normal install sequence follows (again).
Ad 5.
This happens because at #2 during/after the first attempt of install, the UAC was changed (including a message telling so).
yes
fralippo
« Reply #18 on: January 03, 2017, 04:42:23 pm »
Immediately after FIRST XXHighEnd.exe file start I got popup to reboot in order to change UAC. Immediate restart followed.
The other pictures were taken LATER, after various reboots.
I'm 99% sure that memory was NOT set to SC by default!
« Reply #19 on: January 03, 2017, 04:45:35 pm »
You can make that 100%. Happy Happy
Small problem : Now I still don't know what happened ...
You also did not apply other (OS optimization) software ?
Didn't apply Registry tweaks yourself ?
(not that you are not allowed to ... I am only trying to find the cause of this)
fralippo
« Reply #20 on: January 03, 2017, 04:49:25 pm »
I do confirm: no OS optimizations and/or registry tweaks.
I obviously only installed latest drivers from Asus website for motherboard. Chipset, Intel Management Engine, Ethernet, VGA and Xmos board.
« Reply #21 on: January 03, 2017, 04:55:46 pm »
I think I can see what happened ... me implying a nice bug ...
After testing this all I changed something like UseUACDown (meaning no Apps possible) into UseUACUp (meaning Apps possible). This, as a state, is checked here and there. But because the meaning of the state went opposite to how it was at first, I had to change tests for it like
If UseUACDown
into
If Not UseUACUp
... and I now see a place where this "Not" is missing ...
fool
So issue found !
Again thank you for all your help.
