April 08, 2025, 11:50:16 pm *
Author Topic: 2.07 a great christmas surprise  (Read 48020 times)
briefremarks
« Reply #15 on: December 30, 2016, 09:36:55 am »
I just upgraded the Stealth Audio PC to XXHE 2.07.  Peter: you have made this so easy now, with the 2.xx folder!  Listened to a few albums, and I can hardly believe the further improvement in SQ.  What a lovely Christmas gift.
I was noticing Peter's signature line, and see that the clock res is set to 1ms, and not the earlier suggested 15ms.  I also noticed the DAC device buffer at 4ms, not 16ms.  Is this a revision based on the Phisolatar and B'ASS setup that you have Peter, or generally applicable for those using the Stealth PC.
Wishing everyone a wonderful new year!
Ramesh
XXHE version 2.11.
« Reply #16 on: December 30, 2016, 10:22:11 am »
Ramesh,
My settings spring (and can only spring) from my current gear, which is including the B'ASS and stuff. I must add : sadly. But please notice that this is already so (including the B'ASS I mean) for 18 months which is longer than the Stealth exists.
Putting real value to my settings is thus difficult at this moment with the notice that different incarnations of B'ASS already imply differences (last quite huge one was only yesterday !).
Soon all will be settled.
« Reply #17 on: December 31, 2016, 01:20:47 pm »
It may be because I´ve been away from home a few days without listening music or because the new 2.07 sounds really better, the fact is that this new version is a great gift for 2017. Thanks Peter!
Happy New Year everyone!!
Robert
« Reply #18 on: January 05, 2017, 01:59:58 am »
Hi Happy New Year,
                          Well I have downloaded 2.07 upgrade patch and after several restarts its going ok so far. Still some 24/96/192 albums skipping in some tracks when I load the whole album. If I load single tracks it doesn't skip.
For the RAM-OS Disk and booting from RAM, the Timer settings could not be applied previously. Now they can. In order to let this work, apply this (you 'll need to do this one time only, but for each OS you boot from RAM) :
This is working for me, but I have a question.
Do I have to reset "Refresh and Apply buttons in Timer settings" everytime I play a new album in Ram OS? I notice when an album is cleared after listening the settings show they are not set?
Otherwise 2.07 sounds great and a definite improvement. I have left Intona in the circuit for now.
Robert
Oppo 205 UDP Dac
JLAudio 12 Active Subs x 2
briefremarks
« Reply #19 on: January 05, 2017, 02:23:12 am »
Robert,
There is a note in the 2.07 upgrade that indicates that for 2.07 SQ improvements it is necessary to go back to Base OS, then min OS, and then min RAM OS.  Wondering if everyone is doing this right away after installing the upgrade because I did not, and only later realized that it was needed.
Just in case anyone else like me missed it when reading the upgrade notes.
Ramesh
XXHE version 2.11.
Robert
« Reply #20 on: January 05, 2017, 04:21:55 am »
Ramesh, yes I did that to reset the Timer/Timing settings after install and it worked perfectly. I'm just not sure about resetting Refresh in Xxhighend while playing albums or songs when listening. Or when resetting at install this is all that's required.
Robert
Oppo 205 UDP Dac
« Reply #21 on: January 05, 2017, 12:32:06 pm »
Robert,
Nothing needs to be re-applied. And if you look at the current state, always do Refresh and nothing else.
More clear now ?
Robert
« Reply #22 on: January 10, 2017, 09:44:11 pm »
Thanks for the Refresh button activation point.
I have reversed my Bios CPU core setting back to Auto but disabled Turbo to see if that makes a difference to skipping issue(24/96/192). Perhaps my computer is running light on cores and power. Anyway it seems to be working for hires files.
I compared the latest HQ player(Trial) and wtfplay(Linux) with XXhighend and boy was the difference massive. Noticeable immediately. No competition for 2.07.
The best sound I have ever had from my computer this latest XXhighend 2.07!!!
Robert
Oppo 205 UDP Dac
Stanray
« Reply #23 on: January 10, 2017, 11:05:56 pm »
Last week I installed XXHighend 2.07 and a few days later started using the RAM-OS disk with Windows 10 14393 so I’m not really shure what’s responsible most for the huge improvement in sound quality (I guess the RAM-OS is the most dominant factor).
I’m not going to try to describe the different aspects of the sound improvement, only that the past week I listened longer and with more pleasure than ever before.
Concerning the BIOS settings, there was a time when we changed these to improve SQ. With the current setup-RAM-OS/W14393/2.07-is there any need to change those settings or maybe just not change them (as Robert implies above)? Are there any crucial BIOS settings now?
Anyway, thanks again Peter  thankyou
Stanley
Robert
« Reply #24 on: January 10, 2017, 11:36:14 pm »
Unless you have the new Stealth, Bios settings are totally in your hands especially regarding individual hardware. I've been using the old XXHE computer Bios settings but my computer only has 4 cores, 8 threads.
In the light of changing Bios settings I hope I've solved a problem. As a result of the sound being so good I can't not listen to 2.07. I played the latest St Germain - St Germain 24/44, wow detail and bass not heard before. In fact probably need to rework my subs now.
Robert
Oppo 205 UDP Dac
« Reply #25 on: January 11, 2017, 08:57:09 am »
Hi guys, thank you for the responses.
Stanley, the BIOS settings in the Stealth are for the majority the same as layed out for the "XXHighEnd PC". The Stealth has many more settings, but they remained untouched (were not explored or were regarded wackey by me for the processor we use (this was confirmed by ASRock).
« Reply #26 on: January 13, 2017, 03:41:07 pm »
I totally agree with all the positive comments regarding the SQ of 2.07. To my ears it sounds 'cleaner' and 'clearer' than 2.06a. With 2.07, it's almost as if I've reduced the SFS to very low level (I haven't), BUT the sound remains nice and full (as opposed to too thin or anaemic, as low SFS tends to produce).
I hope this makes sense.
