April 06, 2025, 08:56:59 pm *
Author Topic: 2.07 a great christmas surprise  (Read 47990 times)
« on: December 24, 2016, 10:47:39 pm »
It was a very nice Christmas Eve suprise  to see 2.07 posted today.
We have really been enjoying carols playedbwith 2.07 today, very nice sound. Definatly a big step forward from 2.06 here.
Thanks and Happy Christmas.
Arjan
« Reply #1 on: December 25, 2016, 12:47:29 pm »
Yes, the SQ of 2.07 is a pleasant surprise.
Arjan.
March, 2024 (2.11)
grom64
« Reply #2 on: December 25, 2016, 04:11:45 pm »
Peter!
Thank you for 2.07!
Merry Christmas!
Basil.
Audio PC/ W10-14393.0 RAM/ XXHighEnd 2.10
Engine#4 Adaptive Mode / Q1/-/3/4/5 = 20/-/1/1/1/ Q1Factor = 30 / Dev.Buffer = 4096 / ClockRes = 15ms / SFS = 10,19 (max 60,19)/ Scheme = Core 3-5/ Minimize OS/
"LivingAthmos" Referens, Ultimate, "Weiss" 202 int, "Concert Fidelity": DAC-040BD, 080-LSX2V2, ZL-200SE, "VP Acoustic" (by ACCUTON)
dsm
« Reply #3 on: December 25, 2016, 07:22:15 pm »
Thank you Peter.
What a nice surprise today and the changing of the UAC requirements will make using Tidal so much easier for me.
Merry Christmas to you and your family.
David
« Reply #4 on: December 26, 2016, 02:36:51 am »
Yeah, wonderful Christmas surprise. Sound is fantastic and I love how much quicker volume changes happen. Thanks most mysterious sound quality  lab.  Happy
« Reply #5 on: December 26, 2016, 07:41:04 pm »
Further note on speed of volume change: ticking "don't do anything with cover art" causes volume to change much faster in unattended; unticking "do nothing with cover art" and using mirror back, volume change takes longer but cover art doesn't seem to change SQ. Hope I'm not imagining this.
« Reply #6 on: December 27, 2016, 09:39:45 am »
Hi Brian,
There's just one Do and Don't too much for you or me. Can you check your text for that and repeat in "better fashion" ? Of course it is about the last one only, but since you make a mistake in the first two, I can suspect a mistake in that last one just the same. And I can also tell you that the last sentence seems to bear some inconsistency. This is not a matter of life and death but it is a matter of do or don't (for me) - haha.
« Reply #7 on: December 27, 2016, 03:30:27 pm »
No mistakes. Activating cover art (Unticking "Don't Do Anything With Cover Art") causes volume changes to take a bit longer. However, after A-B'ing yesterday, I was mistaken about SQ. Activating cover art just kills the sound here.  So I am back to "Don't Do Anything With Cover Art." However, love the sound of 2.07!
« Reply #8 on: December 27, 2016, 03:53:51 pm »
OK Brian, thanks. I am ging to try that too ...
« Reply #9 on: December 27, 2016, 06:13:41 pm »
Peter after disabling cover art reboot the audio pc and you will then have the volume changing very quickly in unattended. Just switching back and forth regarding cover art, without a reboot, causes volume to be slower with and without cover art, but if you disable cover art, reboot and then play unattended, volume changes take 10 seconds or less.
« Reply #10 on: December 27, 2016, 06:33:13 pm »
Interesting. But to have it clear for myself, your mentioned "10 seconds or less" is the fast version, right ? How slow would it be in slow-mode (so to speak) on estimate ? (no need to stopwatch)
Thanks a lot,
« Reply #11 on: December 27, 2016, 07:28:31 pm »
I'd say around 20-25 seconds
« Reply #12 on: December 29, 2016, 02:27:40 am »
I just had the occasion to install the patch over my XXHE 2.06 (win 10 b. 14393). Wow, it is even clearer and live than the previous version!
These days I am listening to Link Wray, an artist that played guitar with a lot of distortion. There is a lot of vibrations and variations. They are rendered with more depth then I recall with 2.06.
Another level has been reached. Each time I wonder if i is possible to go even further... I probably should stop asking myself each time Wink
Thanks a lot Peter Happy
briefremarks
« Reply #13 on: December 29, 2016, 04:57:15 am »
A quick question on installing the 2.07 upgrade.  I want to do this on both the Stealth Audio PC (running 14393.0 from RAM-OS) and the original XXHE Music PC (running W8 from HD).
- The Stealth PC came with what is identified as 2.06b.  Does the patch work for this version?
- I am also somewhat ignorant about the proper activation process when installing the patch on a machine not connected to the internet.  Presently neither the Audio PC or the Music PC are connected to the internet.  Do I get a code from a machine connected to the internet, and then use it?  I thought it was necessary to get the activation code from the machine where it will be used.
- Any special procedure required for the XXHE that came already activated with the Stealth PC SSD?
Still catching up on so many fronts.
Ramesh
XXHE version 2.11.
« Reply #14 on: December 29, 2016, 10:21:54 am »
Hi Ramesh,
The UpgradePatch can just be installed over the 2.06b and in that particular folder (named 2.xx in there). Not (re)activation related whatsoever.
If that W8 machine is not updated to 2.06, you'll need to upgrade to 2.06(b) first by means of the previous UpgradePatches, or install the complete 2.07 in a new folder. That too should not imply reactivation but often people don't follow what I expect they should and the lot gets deactivated (but blame me).
Either way no connection to the Internet is needed because I can arrange things from here for you (or others). Just drop me an email. Best would be, though, when you try yourself the UpgradePatch which is contained in the 2.06 (Relasenotes) because in the end this is the easiest and can not fail (and this too counts for everybody).
