November 24, 2024, 03:42:24 am *
Author Topic: Please post problems in your "own" topic !  (Read 5030 times)
« on: February 17, 2008, 08:40:08 am »
Hi all,
Please create your own topic (with a description to the point) of the problems you have. All your problems will be different anyway and need different attention per case.
Also please indicate what it is you are trying to do ! Examples :
- I try to play a normal 44.1/16 the normal way;
- I try to play a normal 44.1/16, but I try to squeeze more bits into it.
- I try to play a normal 44.1/16 which couldn't work before because of my soundcard doesn't support 16 bits officially so it should go now ?
- I try to play a 96/24.
Always relate it to the earlier situation. Otherwise I can't tell whether I broke something, or that it still doesn't work.
Thanks !
