April 05, 2025, 10:40:31 pm *
Author Topic: Interface won't resize  (Read 8989 times)
knutus
« on: November 26, 2016, 10:40:51 am »
I usually use foobar2000 because the simplicity of it. But then, occasionally I want the sound quality of xx. But when I opened xx this time the UI only opened up just as a small rectangle (approx 20x15 cm) up  in the left corner, and it was impossible to resize. It just didn't work. Note: I've got the recent windows 10 update (1607), has that got something to do with it?
Fujitsu HTPC, m2tech Hiface DDC, Abrahamsen (Electrocompaniet) DAC, S.A.T. Amplifix (Bladelius) integrated amp, B&W DM603 s3 speakers, cables from Supra, van den Hul and Audioquest, various feets and tweeks mostly home made/experimental
« Reply #1 on: November 26, 2016, 10:55:44 am »
Hi !
What version of XXHighEnd is this ?
OS ?
Is it possible to post a screenshot of this ?  (can do that via Additional Options when posting)
knutus
« Reply #2 on: November 26, 2016, 11:06:33 am »
I edited the text after you responded to it. anyway, it is supposed to be the latest version of xx, and the screen view is what you'd expect before you resize it. Only it just didn't work.. But can you give me a min? Maybe it will work if I reboot the computer? I give it a try..
« Reply #3 on: November 26, 2016, 11:15:03 am »
I have never heard of such a problem ever. I think I really need that screenshot (you can use your phone for it).
Do notice that in the end you will need formally supported Windows 10 builds and you should prevent from updating those (XXHighEnd can do that for you). The latest build supported is 14393.0 (the main xcreen of XXHighEnd will show the build number).
Btw, I am not saying that other builds won't work, but with Windows 10 you can never be sure whether it works "tomorrow" or why today the sound is worse than yesterday.
« Reply #4 on: November 26, 2016, 11:16:09 am »
Something else is that I don't understand what you mean with "resize does not work". Doesn't it stick ? can't you drag the borders ? something else ?
knutus
« Reply #5 on: November 26, 2016, 11:27:28 am »
Hi again. I'm not sure if I posted my last note here, because I don't see it in the thread.. Anyway, I hit the B button at the right side of the UI, and Voila Happy It works just fine Happy
« Reply #6 on: November 26, 2016, 11:29:09 am »
Aha ...
Can I assume that you hit that B button earlier on to remove the borders ? I mean, it should be so that by default (right after install) those borders are there. Eh ... obviously.
knutus
« Reply #7 on: November 26, 2016, 11:36:34 am »
Hehe, Uh,, yep Happy Sorry to bother you. And thanks for the (as always) great support! Hope you have a nice weekend Happy Cheers Happy
« Reply #8 on: November 26, 2016, 11:55:39 am »
Thanks and have fun !
