December 21, 2024, 12:51:34 pm *
Author Topic: Tidal Login Failed  (Read 21756 times)
« Reply #15 on: November 25, 2017, 08:34:28 pm »
Hi Gerard,
19:15:37.5831133 : Start Create Session Error (Login) : Het systeem kan het opgegeven bestand niet vinden
I really have no idea at this moment. This is a system message (XXHighEnd's messages are never in Dutch).
Do you have a TidalSession.dat file in your XX folder ? (don't post it)
« Reply #16 on: November 25, 2017, 08:51:05 pm »
No TidalSession.dat anywhere to be found.
A lot of Tidal subdirectories have been created.
I suppose the file can not be created?
Regards Gerard.
PS. I don't want to bother you on your free saturday evening so take your time Wink
« Reply #17 on: November 26, 2017, 07:49:10 pm »
I tried another PC annd there it works.
I'll try to check the differences.
Gerard.
