November 24, 2024, 01:46:49 am *
Pages: 1 2 [3]  All
Author Topic: Can't play with Terratec phase 24FW  (Read 43568 times)
0 Members and 10 Guests are viewing this topic.
« Reply #30 on: February 23, 2008, 06:24:33 pm »
It is plain impossible that *and* Needs 24 *and* needs 32 is supported. So put your bets on 32 only, and try now.
Note that it can do "more" than before. If you only have errors now while before something played, then I must be careful with what I did.
So please let know ...
« Reply #31 on: February 23, 2008, 06:28:43 pm »
I'm not sure to understand: do you want me to put 32 bit/something in the dac properties and try again to play something?
I decided to go ahead and i'm installing SP1 right now.
« Reply #32 on: February 23, 2008, 06:38:30 pm »
OK i cancelled the SP install and i'm gonna try playing a wav, with dac set at 32/96.
BSOD again.
I'm gonn ainstall the SP1, i dont see other solutions.
« Reply #33 on: February 23, 2008, 06:58:13 pm »
I was trying to make clear to not try any "DAC Needs 24" setting, and only 32. I estimate the 24 can't be right (wrongly reported by Vista / the Terratec driver) and when you try to play with it, things go severely wrong. Before it couldn't come that far because something else in Vista said nothing was possible.
Don't forget the Double option (and "Needs 32") which I'd put my horses on. Also keep in mind : it would be the most logical for a DAC (Soundcard) which supports 24 bits to play 96K files. 88.2 would do too then. And otherwise ... try a genuin 96/24 file now ...
scratching
« Reply #34 on: February 23, 2008, 11:11:57 pm »
The SP1 did not fix the BSOD.
BTW, the program hangs up (not responding) when i click on the library tab and then to another one.
« Reply #35 on: February 24, 2008, 12:00:50 am »
I am really sorry, but I can't determine from your posts when exactly this happens, except for always.
Here too, messages like this I can't deal with. Is this caused by SP1 now ? was it in the few minutes you could try 0.9u-1 the same 9 (I bet not) or was in with 0.9u-0a as well ?
Please try to be more clear, as well as maybe you can answer my questions more precisely. Before SP1 I don't think you quite did already, and now *I* am lost ... Cry
In each occasion try to imagine that I really can't guess what happens in which situation. IOW, tell EVERYTHING you can imagine I can't guess. Ok ?
« Reply #36 on: February 24, 2008, 01:34:12 am »
When I push the library tab, I have to wait a few seconds for the explorer window to pop up... if I push any buttons while explorer is still loading I get no response... patience?  Can be a tiny pain if I push library tab and then quickly want to go to a different tab... but if it's just slow computer or whatever... it's only a few seconds wait that I can learn to live with.
« Reply #37 on: February 24, 2008, 06:47:49 pm »
Quote from:  Telstar
I shut down xxhe and this time without doing anything i hit play, and it started playing without errors. I hit stop and poof, BSOD irql_not_less_than_equal
Today I coincidentally ran into a post mentioning this error as caused by the (W?)LAN driver.
Also, if you have Bluetooth on board (and you don't use it), try to uninstall the drivers for it.
« Reply #38 on: February 24, 2008, 10:07:38 pm »
Last night I saw the wait had more to do with waiting for my albums picture/selections to show up then it did explorer...(different folders with varying amounts of wavs would load faster/slower depending on how many albums where in folder/gallery).  My largest gallery only takes a few seconds to load... no biggy.  If I go to a folder with no wav folders... explorer window pops up quick.
« Reply #39 on: February 25, 2008, 11:05:42 pm »
Quote from:  Telstar
That BSOD can be caused by almost anything. But because my machine is rock solid, the only cause is the audio. Either terratec driver, or the handing of the pci use by the mainboard or something in the latest version of xxhe.
Pages: 1 2 [3]  All
Page created in 0.081 seconds with 19 queries.
