November 22, 2024, 09:55:03 pm *
Author Topic: Damn Caller J problem is back with FLACs  (Read 7709 times)
« on: October 27, 2016, 06:17:56 am »
A while back I had a problem playing FLACs (but not WAVs)...
http://www.phasure.com/index.php?topic=2895.0
...if I remember correctly this was because I had 16 cores and XXHE supported 12 (at that time).  You did something to XXHE and the problem went away.
As you know I now have my new AudioPC up and running with a 20 core E5-2698 V4 hyperthreaded to 40 cores.  I am getting the same problems as I had in the above thread when playing FLAC files, so it sounds like this is the same issue, I have 40 cores and XXHE supports fewer than that.
Anyway, WAV's play well and the sound is pretty decent too, so this topic is just a reminder to please enable more cores to the next iteration of XXHE so I can play my FLAC albums.
« Reply #1 on: October 27, 2016, 08:27:15 am »
Anthony,
Because that other topic was about a sheer bug, can you test without hyperthreading please ?
I suppose it will help, but need to be sure.
Thanks !
« Reply #2 on: October 27, 2016, 11:13:59 am »
No problem with HT disabled.
« Reply #3 on: October 27, 2016, 11:44:31 am »
Okay, work to do !
I promised that anyway.
« Reply #4 on: October 28, 2016, 03:27:07 am »
Page created in 0.117 seconds with 19 queries.
