Arjan
« on: October 16, 2016, 08:19:17 pm » |
Hi, Got my Stealth Mach II last Friday and I like it very much. But.....
The combination with Intona only works with a cheap USB between PC and Intona. And not with the Clairixa in between. I get fifo errors, hiccups in the sound. The Clairixa between Intona and NOS1a is no problem.
I also tried to switch the short and long Clairixa's but same result. Two 'broken' Clairixa's? I do not think so.
I remember that I had the same issues before with my old PC. But that was solved when I changed the PSU used for the USB card. So it has also a relation with the new lineair PSU of the Stealth.....
Are there others having similar issues?
So far I think it might be an Intona issue. But before contacting them I would like some advice.
Regards, Arjan
« Reply #1 on: October 16, 2016, 08:25:19 pm » |
Hi Arjan, absolutely no issues here.
I have two Intona units here. I haven't tested both with the Mach II, but I remember having issues with one of them with other PCs. Daniel at Intona was more than happy for me to return it and to take a look at it, but I've not gotten around to doing that yet (it works fine with the Mach II). It may be worth your getting in touch with him...
Arjan
« Reply #2 on: October 16, 2016, 08:33:05 pm » |
Thanks for your reply. I will contact them. It makes sense that it is the Intona. I already had some issues with my Intona in the past so it is now time to solve it.
Regards, Arjan
briefremarks
« Reply #3 on: October 16, 2016, 10:54:24 pm » |
Arjan,
I experienced some sporadic issues with the Intona box with the original XXHE that went away when I used the short cable on the DAC side, but I have had no issues with the Stealth PC and Intona.
I do know that XXHE on the Stealth will stutter, click, etc. if you are using the Q settings recommended with bootup of BASE OS, and not RAM OS.
Ramesh
« Reply #4 on: October 17, 2016, 09:30:10 am » |
Arjan,
Notice that the PC has a switch in the back to disconnect from mains earth (Off is disconnected). This switch may matter, even when the mains cord is not in an earthed socket. This now works in conjunction with the 3rd switch on the NOS1a, assumed that you have that operable, which I by now forgot for your NOS1a (the first two new NOS1a's did not have that switch used for the famouw "black wire" and you were one of those two first). But I recall you connected the wire to that switch yourself ?
Anyway, a few combinations exist with these two switches and I am 100% positive that any USB isolator will show more or less errors depening on the combination *IF* the errors are prone to show to begin with (and that may depend on the isolator). I am not saying that you should solve it by this means - I'm only expressing my observations although not from the Intona (this never shows errors in my situationS as far as I know).
Arjan
« Reply #5 on: October 17, 2016, 07:52:28 pm » |
Hi, Intona advices me to do an firmware upgrade. I will do that first.
Regards, Arjan
Arjan
« Reply #6 on: November 16, 2016, 10:36:01 pm » |
Firmware is update, but the issue still exists. That is a pity. Maybe my Intona is wrong somehow.
Will do some tests with the grounding switches first.
After that I will contact Intona. I am thinking about buying a new intona. Just test it, when okay I keep it when not okay I will return it.
regards, Arjan
Arjan
« Reply #7 on: November 17, 2016, 12:06:01 am » |
I did some further testing. The grounding did nothing.
But, I only get the USB and Fifo errors running unattended! And after alt-X, when the screen is up again, the ticks are gone.
So I have a kind of workaround to avoid the ticks in unattended, do alt-X directly after the music starts.
But maybe you have an idea what is going on?
regards, Arjan
« Reply #8 on: November 17, 2016, 09:04:30 am » |
Hi Arjan, This looks very very odd to me. Is it only FiFo errors, or also USB errors ? How many of them do you see (very) roughly per second ? Does anything change (number of) with changing the buffer size in the NOS1 Driver Control panel ? When you bring up the Driver Control panel to observe the errors, the errors are also present after you use Alt-s during Unattended (do not bring up XXHighEnd) ? No further questions.  Peter
Arjan
« Reply #9 on: November 17, 2016, 09:58:26 am » |
Can this be done while unattended? How? I did not tried it but just a question.
regards, Arjan
« Reply #10 on: November 17, 2016, 11:15:12 am » |
Arjan - You mean the bringing up of the Control Panel and let it stay ? Obtain (phasurenoscpl) in Processes to Keep (Services section in Settings). If you now start it, it will stay during Unattended Playback.
Regards, Peter
« Reply #11 on: November 18, 2016, 05:16:24 pm » |
Arjan,
It isn't coincidentally so that you see these errors at a (Driver Control Panel) Buffer Size of 8ms ? Or even that you see these at a Sampling Rate of 44100 and 8ms ? I see something odd myself for this exact combination ...
Arjan
« Reply #12 on: November 18, 2016, 10:28:42 pm » |
I did some testing. With cheap usb there are no errors at all! The errors are only existing with Clairixa between PC and Intona.
USB3 (only driver control panel) With just the driver control panel open the Errors (USB and Fifo) are starting. Within 1 minute the USB errors are 500 and FIFO 2000. At 16ms it seems to be a bit worse but this is not consistent. (all counts are average per minute)
USB3 xxhe unattended The USB and FIFO error count seems more depending on the buffer size. 4ms 500 and 2000 and 16ms 1500 and 10000. (per minute)
USB3 xxhe unattended + altX No errors!
After altS the errors are still counting.
I also tested it via USB2.0 and the results are different. Almost no error with just driver control panel and unattended playback but errors after altX. So the otherway around.
I checked your remark about 8ms an 44100 but I did not see any different behavior with that setting.
Maybe you see any logic in this. I am thinking about buying a second Intona and just see how that behaves. Also errors then I will send it back.
regards, Arjan
« Reply #13 on: November 19, 2016, 10:49:45 am » |
Hi Arjan,
This must be something very peculiar.
Wait ... I was just sitting back for over 5 minutes, contemplating what the heck the bringing up of XXHighEnd('s GUI) can do to this. But I know ... it changes the processor speed. So this is about the "Boost" setting, which you undoubtedly have active. IOW, what happens when this is off, and when "no difference now" what happens when you fool around a bit with the processor frequency. Not that it is the solution when it helps, but it may teach us a few things. I know, you are guinea pig now.
With zero problems anywhere with Clairixa's, you should be the very first and then (indeed) have problems with two of them ? that seems impossible. But still possible. Haha. Maybe there is a poor soldering joint on the input of the Intona which just changes the impedance enough to cause trouble. USB *is* very sensitive you know. This is also how people should not mangle with their USB interface (like reposition it).
What I also noticed is that somehow the USB ports/terminals of this MoBo are not the most firm. So *if* you experience USB errors to begin with, it is fairly easy to incur for more or less when the cable connector is repositioned a little (which can be done and which tells something as well). This is also how USB2 may work better because those terminals are more firm; try it !
Best regards, Peter
Arjan
« Reply #14 on: November 19, 2016, 12:11:07 pm » |
CPU speed has influence.
With boost off the workaround altX is not working anymore. Also then I have errors.
With boost on after altX no errors.
Also with boost off I almost always get the "Attempts: 11 Current CPU% level of process : 6.433237. Continue?" Yes/No. And with Yes music starts (with ticks)
With Balance load on 100 there are no errors when music plays unattended! (with or without altX). But the errors are still counting when music stops.
Also it seems not possible to go much beow the 100. Maybe 98 but with 95 I get some errors again.
It has to do something with CPU speed.
regards, Arjan
