« Reply #60 on: November 06, 2016, 11:52:48 pm » |
What a total mind f**k...
I posted the 3 files on Audio Science Review. Ray Dunzl did some analysis on them and found that all 3 are absolutely identical (with a few samples added to #3 - I could hear the clicks but couldn't get rid of them).
And having seen his null results, I'm now having problems hearing any differences between the files!!!
I would have been surprised if the files were anything but "bit perfect" so to speak, or "identical"...these sorts of conversions are well sorted in the modern world. As to what you hear when your mind has new information to digest then...well...that is quite well documented.
« Reply #61 on: November 07, 2016, 08:32:44 am » |
So Anthony, what were we hearing when we said things like: 2. microRendu -> USB-to-spdif converter -> BNC cable -> Tascam recorder digital input
Flatter than the original CD rip - the dynamics are not there. But the colour/tone is pretty similar. I think this is about as good as you're going to get before getting into a fully optimised audio PC like the Mach II. For the cost of the microRendu/LPS-1, it's very good... but certainly not perfect. I'm sure the microRendu crowd on CA wouldn't agree...
3. Mach II -> USB-to-spdif converter -> BNC cable -> Tascam recorder digital input
OK, the dynamics are back. Very, very close to the original CD rip, though I feel there is a slight 'hardening' of the sound. The cymbals now sound 'cheaper', i.e. made of a thicker and inferior metal. I have SFS=4.00 and Q1-5=0 (xQ1=1). It might be possible to 'tune' the sound to become closer to the original by playing around with the XX settings - something that I'll do going forward, if I have the time and inclination. It also occurs to me that maybe this is 14393 showing some of its attributes?
#2 is not though, it interferes too much. But why the heck is the bass (well, lower mid) is the disturbing factor ?
#3, strangely or maybe better : unexpectedly, is the best background music. It simply is (also) the best musically exhibiting. It is just flowing .... The original CD Rip is clearly the best sounding here, reasonably closely followed by the third through the Mach II where there is some loss of clarity and perhaps a touch of dynamics. The second file through the Microrendu is flat, thick and unresolved. The transients are flattened, the soundstage is less deep and it is what I would call a large departure from the CD rip.
Most notable is the piano rendition of the Microrendu: the touch of the hammer is muted and dull compared to the other two versions, and the notes are quickly truncated and fail to hang due to the lower resolution and smearing of other instruments and notes.
Saying that, I don't think the Mach II is perfect either, but it is much, much closer to the original CD rip, and remember that I am not playing back using a Mach II.
We've just established that the 3 files were identical (a few added clicks in #3). There simply could not be any sonic differences between them, right? BUT... we heard differences. All in our minds? Mani.
« Reply #62 on: November 07, 2016, 08:48:31 am » |
At least I was lucky to be so ignorant to judge the #3 as the best sounding, even after knowing (finally) that the #1 was the original. Btw, I did not expect the files to be different. I mean, not one single moment I even considered it. IOW : Make two of these recording from your best (or worse) setup and, for example, have the SFS different between the two. Now too, I wouldn't even consider that the files could be different. They just ARE the same. So don't worry.  Peter
« Reply #63 on: November 07, 2016, 09:52:23 am » |
So don't worry.  For me, it's a reminder that remaining objective is bloody difficult. Mani.
« Reply #64 on: November 07, 2016, 11:16:38 am » |
My main point was that something would be wrong if the files were not the same. For instance, as Peter said above, we can influence the sound in XXHE by changing this dial and that one and minimising the OS but in all cases the bits remain the same, they are not changed. How do we change the sound with those dials? By changing the behaviour of the cpu and other parts of the computer and altering how the transport (MR or Mach II in this case) interacts with the DAC.
« Reply #65 on: November 07, 2016, 11:25:41 am » |
Yes I agreee. XX can only influence the noise getting to the DAC - there is no possible other explanation for why any of the XX settings change the sound.
But back to this 'test'...
Why did you, Peter and me hear a difference between the 3 files... when they were absolutely identical?
« Reply #66 on: November 07, 2016, 11:31:21 am » |
Why do you hear a difference when you change XX dials ?
« Reply #67 on: November 07, 2016, 11:34:54 am » |
Actually there is only one thing that worries me : that I judged #3 to be the better one (over #1). Oh, I can live with it all right, but if I am correct with that judgement (notice that Anthony already does not agree), I am eager to apply a similar improvement without the hoopla of recording the digital file (output by the Stealth) digitally first. haha
Regards, Peter
« Reply #68 on: November 07, 2016, 11:38:15 am » |
Why do you hear a difference when you change XX dials ? XX can only influence the noise getting to the DAC - there is no possible other explanation for why any of the XX settings change the sound.
« Reply #69 on: November 07, 2016, 11:40:20 am » |
... but if I am correct with that judgement...
And this is exactly my point - you were not correct with that judgement! It's an absolute impossibility... The 3 files were identical!!! You, Anthony and I were hearing differences that were simply not there. Mani.
« Reply #70 on: November 07, 2016, 11:48:02 am » |
I'm going to redo the test, but this time through an DAC and then ADC. The path will be:
microRendu (no DSP) or Mach II (no DSP) -> Chord 2Qute DAC -> Prism AD124 ADC -> Tascam spdif digital in
In this case, even though the mR and the Mach II are producing bit-perfect outputs (as proven by Ray on ASR), we certainly should expect to have a difference in SQ. We'll see...
Oh and BTW, this time I am not going to reveal which captured file is which! Let's get any listening biases out of the way.
« Reply #71 on: November 07, 2016, 11:48:14 am » |
Are you now serious ? If so, you may have lost it.  (referring to your one but last post)
« Reply #72 on: November 07, 2016, 11:51:37 am » |
If so, you may have lost it. OK, I did myself.
« Reply #73 on: November 07, 2016, 11:53:07 am » |
Are you now serious ? Of course I'm serious! #2 vs. #1 nulls to zero. #3 vs. #1 nulls to zero (if clicks ignored). On conversion in the DAC, there can be no difference between the 3 files. It would be like loading file #1 three times and hearing a difference between them, surely? Peter, please enlighten me - where am I going wrong with my thinking? Mani.
« Reply #74 on: November 07, 2016, 11:56:57 am » |
Peter, please enlighten me - where am I going wrong with my thinking? No-where so far. The mistake I made today was thinking about the offsets and difference with filtering (you will remember from CA-Dennis). But then I saw your "no DSP" in you later post and it reminded me about the not-upsampling you applied. So there can't be a filter and thus also no difference implied by that PLUS that it is all digital to begin with and no difference is no difference. Did I hear the same/similar differences in both the files (your example track and mine) or do I suffer from amnesia ? Peter
