April 08, 2025, 08:32:39 pm *
Author Topic: RAM-OS: message "info:total sectors calculated from partition...."  (Read 6330 times)
« on: October 08, 2016, 02:10:13 pm »
I'm now working with ram os disc. From the start working with the ram-os, i get a message during booting " info: totalsectors calculated from partition table (51199155) is less number of sectors in the whole disk image (51200001).
Probed C/H/S = 3187/255/63. Probed total sectors = 51199155
[24792M/25000M]
When the last numbers are equal the following short message:
filesystem type is ntfs, partition type 0x07
Will boot NTLDR from drive=0x88, partition=0x0(hidden sectors=0x800)
Windows starting and all is functioning ok. I have this message from the start working with the ram os disk. I have internal 32 GB RAM, so i expand the RAM OS Disk partition hoping to get rid of this message. No effect on the message.
Any suggestions?
Regards Johan
Pm so far i can judge all sounds good. I have to fix my tube amp.
« Reply #1 on: October 08, 2016, 03:43:39 pm »
Hi Johan,
That message is perfectly normal !
« Reply #2 on: October 08, 2016, 11:20:36 pm »
This is what you mean with your unboxing ram-os disk instruction: "Notice that a bit depending on your PC it can take 3 minutes for the boot accomplishes"
Johan
Page created in 0.011 seconds with 19 queries.
