April 06, 2025, 04:15:16 am *
Author Topic: Adding 14393.0 to the menu failed  (Read 21837 times)
« Reply #15 on: August 26, 2016, 02:39:10 pm »
Ok, here's the thing to try then. I hope I don't make mistakes :
Boot into any of the OSes BASE or RAM (thus not TRIAL)
Open a command prompt "As Administrator".
In there, type this :
bcdedit /store d:\boot\bcd /default {16c73821-518e-11e5-a49f-dd1005622084}
[enter]
(copy - paste this line into the command prompt (that works) but without the [enter] of course (I put that on the next line for comfort)).
... and although this could help, I seriously doubt if doing it via XXHighEnd (lateron) will work. I think not, because something looks strange.
So, after applying the above, if all is right you will boot into 10586.0 BASE. This is not what you want, so in the Boot Menu of XXHighEnd you're again going to appoint another (like 14393.0 RAM). Does that work ?
If not, you know how to do it via the Monitor (for temporary recovery).
I am curious ...
« Reply #16 on: August 27, 2016, 12:01:31 am »
That works Peter.  I booted into W10586 RAM, used your command line, rebooted and it went into 10586 BASE as you said it would.
In 10586 BASE I selected 14393 RAM in XXHE then Apply then Resfresh and the XXHE menu did not show the selected OS properly in the menu...but I rebooted anyway and it booted properly into 14393 RAM.  Good.
From 14393 RAM I selected 10586 RAM from the XXHE boot menu and again after refresh the XXHE menu did not show the selected item properly, but again I rebooted anyway and it booted into the right OS.
So it seems at this stage that the only problem is that the XXHE boot menu is not refreshing properly even though things are booting properly now.
« Reply #17 on: August 27, 2016, 07:50:29 am »
Hi Anthony,
Ok, all good;
I don't even know whether it shows the current choice (right after a change) properly/decently. It may also depend on the combination (from - to).
If you lateron might think of what could have been gone odd at your first attempt (around the copying of 14393.0), don't hesitate ...
« Reply #18 on: August 27, 2016, 10:23:50 am »
When you change the OS and then click Refresh, the incorrect, or sometimes no OS is shown as selected, but when I reboot it boots into the correct OS and the Boot Into menu shows the proper OS selcted i.e. the one that was just booted into.
It's a minor issue.  Not sure if you know about it or if it is unique to me.
Thanks for getting things working for me.
« Reply #19 on: August 30, 2016, 10:40:23 am »
Anthony, I just checked it, and indeed this is so; changing the boot and click Refresh reflects a wrong situation (and indeed it may depend where you're in at the moment).
A Refresh for changed descriptions should always work.
