November 23, 2024, 02:25:38 am *
Author Topic: XTweaks Settings in RAM OS  (Read 7199 times)
Robert
« on: August 22, 2016, 07:55:56 am »
           Under "Use Settings" the boxes have BL 43, NR 100, CI -, SP 0,
Cores 1.
After playback(Min OS RAM) when it returns to rest the numbers in the ( 0 ) are the same but the top one BL is 100. I push button apply and it returns to 43.
Is this necessary? When in BASE OS I always set everything before setting Min OS. Then run in RAM OS.
Robert
Oppo 205 UDP Dac
JLAudio 12 Active Subs x 2
« Reply #1 on: August 22, 2016, 09:22:09 am »
Hi Robert,
Switch Off "Boost at XXHighEnd Startup" (in XTweaks). Then it will be as how you were used to it. But startup of XXHighEnd will be slower (again).
Robert
« Reply #2 on: August 22, 2016, 10:24:38 pm »
When you run Ram OS do you leave the settings as set as per what I describe and not touch the apply button for normal playback.
I'm not trying to go back to any former settings.
Oppo 205 UDP Dac
« Reply #3 on: August 23, 2016, 04:40:59 am »
Hi Robert,
The answer is : No, because the "apply" is performed automatically when you press Play for Unattended Playback (only for Unattended !).
If it is not clear, let me know.
Robert
« Reply #4 on: August 23, 2016, 05:07:28 am »
Thanks that's exactly what I wanted to know.
Robert
Oppo 205 UDP Dac
