April 05, 2025, 05:37:30 am *
Pages: 1 2 3 4 5 [6] 7 8  All
Author Topic: Your first RAM-OS Disk Upgrade ! 14393.0  (Read 100055 times)
briefremarks
« Reply #75 on: October 13, 2016, 08:28:18 pm »
Arvind,
Just rename the .vhd file without the -Copy.
You do not need to install two files, just one .vhd file in the root D: directory.
You will need to reconfigure network settings and RDC if you are using a LAN connected music server.
You will also have to reset the various Q and other parameters, as this is a brand new OS and does not copy over any settings from other OS versions you may have used.
Ramesh
XXHE version 2.11.
briefremarks
« Reply #76 on: October 13, 2016, 08:41:30 pm »
Arvind,
I thought I'd make it very explicit, so here goes again:
- Extract the .rar file in some temporary location
- Rename the file by removing the -Copy
- Copy the file to the D: root directory
- Bring up the Boot Into.. option on XXHE
- Select the New button in the popup, and select the 14393 .vhd file to add as a new OS, and give it a name; select both BASE and RAM
You should be set to go.
XXHE version 2.11.
« Reply #77 on: October 14, 2016, 05:48:00 am »
Hi Ramesh,
Thank you.
That's exactly what I did but there are a few issues:
1) in the boot into menu against 14393 BASE the "repair file" does not show up. Even if I select the file from the drop down menu->apply->refresh, it becomes blank after refresh.
2) Currently my OS is 10586.0 RAM, if I now select any other OS-> apply-> reboot it only tries to boot into 14393.0 RAM. It shows error & then I have to manually select the OS to boot into. And it only boots into 10586.0 RAM, no other OS.
briefremarks
« Reply #78 on: October 14, 2016, 07:50:01 am »
I had a chance to listen to 14393.0 for a while this evening, using the settings that Peter mentions a few posts earlier.  By the way I do not know where to set the driver buffer to 16ms, so I'm not sure what that setting is.
I've been comparing with 10586 listening mostly to acoustic instruments: piano, guitars, acoustic bass, drums.  I find that I can make better comparisons listening critically at the "sweet spot" (very wide with my speakers), AND listening casually while doing other things--the second method seems to me just as important.
14393.0 is the best version yet! I cannot believe it.  Just when I'm convinced that we've reached the ultimate, Peter continues to evolve the sound towards perfection.  If there is any criticism I have at all, it is a slight lack of "air" relative to 10586.  But I also wonder if the "air" is an artifact, and not real.
Absolutely wonderful sound.
Ramesh
XXHE version 2.11.
« Reply #79 on: October 14, 2016, 09:16:07 am »
Arvind,
See below and name it literally as you see (the blue line).
(I am pretty sure you did not do it like that)
« Reply #80 on: October 14, 2016, 09:51:25 am »
I selected the file D:\MyW10-14393.vhd from the drop down menu (pls look at my first image). Named it & added it to the boot into menu.
« Reply #81 on: October 14, 2016, 09:57:54 am »
Assuming I hadn't done that, would I still get "repair with" W10-14393 against W10- 14393 RAM Memory OS option in boot into menu?
« Reply #82 on: October 14, 2016, 10:45:59 am »
Arvind,
No, you did not. Your first image shows the file with "copy" in it.
Btw, your second image does too, and what you did after Ramesh' his help I can't tell.
Do you really care ? I don't. I only say that you must do what's being told. Whether this is from Tutorials, Emails or Forum posts.
OK, you "must" not do anything, but then don't complaing something does not work as intended. haha.
PS: Use my screenshot for the literal example and not Ramesh his text which coincidentally contains a space in the name; I say this because I see you write a space too.
PPS: Text from the email for your reference :
Notice that the file is named MyW10-14393-Copy.vhd and that it should end up on disk/ssd under the name MyW10-14393.vhd.
Should be sufficiently clear ! Happy
« Reply #83 on: October 14, 2016, 10:53:38 am »
After Ramesh's e mail I renamed it, & added it again to the boot menu but yes possibly there may be a space, which I will check later today.
Will revert back.
« Reply #84 on: October 14, 2016, 04:40:54 pm »
Ramesh, that's in the NOS1 Driver Control Panel (Buffers, and then top most field).
Robert
« Reply #85 on: October 16, 2016, 02:30:28 am »
Peter have you tried, expanding Ram OS from 15g to 25g yet in 14393?
You mentioned 25g being better sounding in 10586.
Also Bios settings have you altered DRAM from Auto? Someone has suggested setting mine to 800 from Auto. This does slow down loading hard to tell if it makes a difference in sound.
Tried your new XX settings so far seems more listenable.  Havn't reversed power polarity. I've had more bass with 14393 anyway but treble has more clarity with 14393 over 10586. Have not removed Intona. I'm trying to listen over a longer period to get used to sound before making changes. Too many changes confused me and lost my way at 14393 introduction.
Robert
Oppo 205 UDP Dac
JLAudio 12 Active Subs x 2
briefremarks
« Reply #86 on: October 16, 2016, 03:51:44 am »
Robert,
I've spent some time listening now to 14393 with the new settings Peter suggested.  I'd say 14393 is a definite improvement over 10586.  I am still using Intona.
Unless I'm hallucinating, 14393 also sounds "louder" for the same volume setting.
The major improvements I can tell are:
- More realistic acoustic instruments (hard to tell exactly what causes this, but piano, guitar, bass, drums are rendered more "live")
- Bass definitely goes lower, is deep and not flabby, I'm not sure if some refinement is being lost, need to get used to it
- Voices, like acoustic instruments are also more "live"
- Classic rock albums that I found hard to listen to, are more manageable--the poor mastering does not seem quite as bothersome
I am definitely NOT going back to 10586.
Ramesh
XXHE version 2.11.
Stanray
« Reply #87 on: October 16, 2016, 08:53:43 am »
For those who don’t use the RAM-OS disk (yet), but do want to install Windows 10 Build 14393.0: Where is this version to be found and what is the best procedure to install?
Stanley
« Reply #88 on: October 16, 2016, 09:35:50 am »
Hi Stanley - That version does not exist yet. But I am working on it.
« Reply #89 on: October 16, 2016, 09:44:02 am »
Robert, yes, I am using 25GB.
No I didn't; I have always found that parameter to be one dimension too much for me; I have too many other things to judge for, keep in my mind, and in a consistent environment, that I probably never get round to this one. If someone tells me (what to set for the better) I will go along of course.
See ? Happy
Keep in mind that this advice was for the Stealth PC, which is very different from any other and which is related to the (linear) power supply in there. So we make it in a certain setup (which is always 100% the same apart from the processor used) and while I can measure that the changed mains plug polarity is for the better, that should or could count for everybody. For any random other PC it tells nothing (also not for the previous "XXHighEnd PC").
