April 05, 2025, 06:00:26 am *
Pages: 1 2 3 [4] 5 6 7 8  All
Author Topic: Your first RAM-OS Disk Upgrade ! 14393.0  (Read 100064 times)
« Reply #45 on: August 19, 2016, 08:43:38 am »
All,
I was wondering ... Does the procedure work in the first place ?
I'm asking because I don't see any feedback so I just wondered. If it sounds like sh*t you can say it too, of course.
Procedure does not work for me.  The instructions are quite vague and can be read a few different ways so I am not sure if I have followed what you intended us to do precisely (well I probably have not it seems),
Uhm ... I wasn't talking about that "procedure" in particular. Merely about the internal working of the new OS. And that that did not work out indeed for the PCs with 16GB of memory, is known by know.
Btw I like to know these "vague instructions".
So FYI, there is not any procedure as such to create the OS in the boot manu, unless you call this a procedure :
1. Copy the OS file to the root of the PC;
2. Add the OS to the boot menu (the 5 seconds work thing).
but also :
3. Hook up the monitor to set up the RDC to that OS.
W10-14393 is not available in the boot menu at computer startup at all.
I am afraid that you did not apply the above 2 steps, with the 3rd as a quite obvious step, although not easy not to think of in advance (but logical as can be).
Are you able to write out a set of steps 1,2,3 from a known starting point?
It is the other way around. Since there wasn't a procedure except 1,2 and you did not apply that at all (I am quite confident Happy), you must now tell what you did.
Showing a screenshot of the Boot Menu of XXHighEnd is a good starting point (for me).
« Reply #46 on: August 19, 2016, 08:48:53 am »
I need to boot into a BASE version to set the network mapping for the music and streaming directories.
Notice the emphasized "a".
You need to boot into the BASE version of the one you want to use from RAM (and theoretically it could be all of them).
« Reply #47 on: August 19, 2016, 10:00:30 am »
And Anthony ... if you respond, please be prepared for some quick back and forth communication so we can solve this quickly for you. Of coure I will need to find your first response so wait a bit for that, but after that we keep on going ...
Meanwhile and to apply some shortcut, give me your log file of this situation. Do this to let that happen :
0. Be sure to not have any USB sticks etc. in there which may occupy Drive D:. Notice that D: is (to be) reserved for the RAM OS Disk when booted from anything but the TRIAL. Check whether this indeed is so (C: is where you booted from (RAM or BASE) and D: is available and is the RAM-OS Disk).
1. Reboot into a for you working version (RAM is fine, but do not remove the Disk).
2. Go to the location of XXHighEnd (always drive C: (!!)) and remove the log files from the TemporaryData sub folder.
3. Start XXHighEnd (no need to switch on Logging).
4. Go to Stop-RightClick - Boot Into.
5. Grab the log files and post them as attachment.
From there, but please including your followed "procedure" (so I can try to prevent the issue for a next) I am sure we will be able to get you going again.
Edit : I split the further posts about this issue to this topic : Adding 14393.0 to the menu failed.
« Last Edit: August 24, 2016, 06:13:37 pm by PeterSt » Logged
« Reply #48 on: August 19, 2016, 02:22:25 pm »
Hey Peter,
I sent an email for the Win 10 build 14393.0 download (the "smaller" revised version)... ?
« Reply #49 on: August 19, 2016, 02:45:55 pm »
scratchingscratching
Alain, I am quite positive that I sent the link to you right away. But it did not happen for real, I see now.
Apologies !
Coming up (again Wink) right now.
« Reply #50 on: August 19, 2016, 03:00:02 pm »
Hi Peter, has it some other advantages besides that the new version takes up less space? In my case with 24GB of memory I have 4Gb free with the current 14393.0 version.
« Reply #51 on: August 19, 2016, 03:14:23 pm »
Hi Juan,
Theoretically Yes but I did not really compare nor notice a difference (I use the small version too).
The "disk space" required will be 2.5GB less, implying that you will have ~6.5GB of free memory (same as I have at this moment). You won't use (need) that 6.5GB though ...
Anyway, you can ask for the "small link" if you want. No problem at all.
And if you as the first next increase the "disk space" again, it is still no problem; this is not a moot thing, because that disk space will be free disk space, and *that* can come handy at times (larger Hires albums).
« Reply #52 on: August 19, 2016, 03:32:29 pm »
Thanks Peter, I send you an email for this new version. I guess that the installation process is the same one, correct?
« Reply #53 on: August 19, 2016, 03:52:30 pm »
Juan, No. It now only requires this :
0. Boot into any of the other OSes.
1. Delete the 14393 file from where you put it (Root of RAM-OS Disk etc.).
2. Put the new one in there.
So the Boot Menu remains to be OK as it is.
« Reply #54 on: August 19, 2016, 04:40:35 pm »
That's ok Peter
« Reply #55 on: August 19, 2016, 08:19:29 pm »
Apologies !
Don't worry Peter. I downloaded it at the office (after reading your post this morning), on a USB key... And I left without it... I am now downloading it again at home...
From a wandering colleague Wink
« Reply #56 on: August 19, 2016, 08:27:48 pm »
swoon
« Reply #57 on: August 24, 2016, 06:14:51 pm »
Anthony,
I split the latest posts about this to here : Adding 14393.0 to the menu failed.
Robert
« Reply #58 on: August 29, 2016, 10:47:42 am »
I went back to 10586 without, then with Intona. It does seem easier on the ears. Is improved with Intona I do have to turn up the volume from no Intona.
I do think there is something about 14393 that is more revealing in the treble. In this mode without Intona I have to reduce volume to output the same loudness of music as the 10586 OS.
I will leave 10586 in place for now.
Robert
Oppo 205 UDP Dac
JLAudio 12 Active Subs x 2
« Reply #59 on: August 29, 2016, 02:09:22 pm »
I must tell (and I am honest) that at several occasions it has slipped through my mind that additional noise enhances (emphasizes) (some of the ?) higher frequencies. Like noise can be added to a photograph and it may comes across as more sharp.
