April 05, 2025, 06:02:20 am *
Pages: 1 2 [3] 4 5 6 7 8  All
Author Topic: Your first RAM-OS Disk Upgrade ! 14393.0  (Read 100069 times)
« Reply #30 on: August 15, 2016, 10:11:58 am »
Robert, now I don't know what you are talking about ...
Assuming this is about 14393.0, this "obviously" was not expanded by you, earlier on. Maybe it looks like that because it is larger to begin with, but ...
If you have 32GB, make it 25GB. At least that is how I used my 10586.0.
If this is not what you mean, let me know.
Robert
« Reply #31 on: August 15, 2016, 10:17:04 am »
I expanded my Ram file(Xxhighend) size back in April 30th this year according to your instructions to 18GB. This is what I have now. At the time you did not recommend to go bigger than 18GB.
Robert
Oppo 205 UDP Dac
JLAudio 12 Active Subs x 2
« Reply #32 on: August 15, 2016, 10:26:21 am »
Robert, I do not recall any recommendation as such. All I know is that the example (of the expansion) works with 18GB (5GB more) ...
You can do what you want, as long as you have read (i9n the OP) that "today's recommendation" is to let it stay as it is (with the notice that you can not go back unless you freshly copy if (from the download) again). Why ? ... because it sounds good as it is (and these things do make a difference).
Anyway, with 32GB of RAM, don't make it larger than 25GB.
Robert
« Reply #33 on: August 16, 2016, 12:08:09 am »
Further to Benchmark driver software I went back to have another crack at installing software from File explorer and after opening Benchmark install file properties and ticking unblock box it all worked perfectly.
I do notice two things upon returning to min OS Ram XXhighend. The first time it loads into Ram, OS says there is an error and it all reboots. The second attempt is successful. This has happened twice now for me on first bootup into Ram. After this it works everytime.
Also once booted into Ram the screen flicks on and off 2 or 3 times then settles. Running XXhighend after this works everytime.
I've left the Ram at 18g hasn't been a problem so far.
For anyone running Ram OS its worth upgrading to 32g Ram especially if you play Hi Res files and upgrading to 14393. Windows OS's will only get bigger.
Robert
Oppo 205 UDP Dac
« Reply #34 on: August 16, 2016, 09:02:01 am »
Robert
in addition the build 14393 has an intense CPU load. Both PC's, office and Audio are more slowly than with 10586. XXH comes up after >60sec. unhappy
« Reply #35 on: August 16, 2016, 09:43:46 am »
Joachim, you are doing something wrong ...
Nothing is more slow with 14393.0 that I can see.
doublelife
« Reply #36 on: August 16, 2016, 10:04:36 am »
Is there a 14393.0 version available for those of us without a RAM OS disk?
PC  i7 / W10 10074 (x64) / hyperthreading ON (12 cores) / 32GB RAM / XX - OS on separate dedicated 256GB SSD - XXHighEnd: 2.03 / Engine#4 Adaptive / 4096 / Q1=14  / xQ1=10 / Q3,4,5=0/1/0 / SFS=4-120 / Straight Contiguous / Clock Resolution = 1.0  / Scheme 3-5 / 16x Custom / Peak Extend = OFF / Unattended / Minimize OS / Phase Alignment = OFF / XTweaks = 43, 100, 1, 1, 1 > 24/768 NOS1a 75B async USB DAC driver v1.0.4 1ms > KGSSHV Carbon amp > Stax SR-009
« Reply #37 on: August 16, 2016, 10:21:10 am »
Paul,
No, not really. Well, the 14393.0 could be, but there's no official XXHighEnd version for it yet.
And a warning (please) : Do NOT play with any "I don't care" versions beyond 14393.0. Because remember, I used a 14383.0 and it sounded like total sh*t. Besides that, I had to adjust XXHighEnd for 14383.0 and I had to do it *again* for 14393.0. And this is all because W10 is "buggy" in MinOS.
In the far end I will be having 14393 myself (as a normal installable OS), but at this moment this is useless because no XXHighEnd for it.
« Reply #38 on: August 16, 2016, 10:28:26 am »
Maybe,
do you change something within the settings of W10, such as disabling services outside of MinOS?
« Reply #39 on: August 16, 2016, 10:34:18 am »
Maybe some additional remarks are required ...
I can see that the further W10 develops, the more backdoor solutions have been applied to things being wrong in the base and which apparantly can not be solved natively. Example :
Would you have followed the development of Windows 10, then you'd have seen that right from the start there always have been problems with "Explorer", which is the main controlling desktop program (the "dwm" program is even more, but this is not recognizable for you really). So maybe we recall the "memory error" from 10074 at shutting down ? well, it has been in there for ages, went away, and is now back again with 10393.0. So alreadu such a thing can not be solved apparently, BUT notice that this happens to us in MinOS (so blame me if you like). Still :
Someone mentioned the flashing 3-4 times right after booting. Yep, that is the OS repairing itself. So it restarts Explorer (which is that main manager). So it notices that something is wrong, and just restarts. This is in there from IIRC 10565 but it was required only once in a while. Now it is quite continuously, if only we first "mangle" (and we do).
What you don't know and see, is how I fight against something like Cortana. You can kill it, but it wants to be back (unless you take the time to sort out how to really disable it). But this is the whole stuff around backdoor solutions as MS applies them : we kill as much as we can, while MS restarts it as a standard procedure now, because things fail so often that restarting it is the solution.
Understand ?
Nothing is slow. But causing stalls is easy and you think it is slow. Watch the taskbar again; is it slow, or is it just stuck all the time, until the internal process restarts it finally ?
It is the latter.
But for what "we" notice, it is us ourselves doing it, because of some service not running.
Example of what is new in 14393.0 vs. 14383.0 :
If you don't set the taskbar to auto-hide in Normal OS, forget it. The settings to do it lack in MinOS. Why ? I don't know. But of course I (XXHighEnd) caused that. Sort out what it is, will take a week, and next something runs we like to get rid of.
In the end it doesn't matter much, because when the Taskbar is stuck it won't auto-hide either.
Not that we care when using Unattended in the first place.
So these were just a few notes. There's much more going on, and I do NOT see things are more slow. Really not.
But maybe I don't look right ! Happy
« Reply #40 on: August 16, 2016, 10:43:13 am »
Good question. But the answer is No.
One thing I seem to have noticed :
I think it was W8 (was it ?) where showing results from "search like" commands implied a delay (could be up to 0.5 seconds). So the result is there as fast (or slow) as ever, but there's also a delay in showing that. As if something first must communicate. This disappeared in W10 (or maybe W8.1 which I never really tried). BUT ... now this is back again. Or at least it feels like that. In the end this can make your work much nore slow (to finish). For example, search for a certain text in the Registry; the result is found fast (as ever), but it shows 0.5 seconds later. Now do this a 100 times (because the Registry is large and contains many entries with the term you look for) and this is 500 seconds of waste.
Without this delay the result shows instantly, and it only depends on how fast you can ask for the next result.
We can call this "slow" but in the end it is not.
But for net result it of course it. And it depends very much on what you do (whether you run into it or not).
I am withdrawing that now. Apologies.
« Reply #41 on: August 16, 2016, 01:59:03 pm »
As I said in other post, everything is working well now. Only point that when I installed the 14393.0 (method 1) the only problem I found was that the Network was lost and did not appear the Servermusic disks. I guess that that happens when install a new version of Windows.
Other things I've noticed is that when change the volume, up or down, with the AutoHotkeys now the process is faster than before. Also if I want to do something with the taskbar in the Audio Pc sometimes it becomes a very slow process.
Otherwise the sound seems better than ever. The highs now seem full of detail and very natural and the bass are stronger and richer than ever. I could not imagine that my speakers were able to give such low bass with a vibration that really is impressive.
« Reply #42 on: August 16, 2016, 02:02:28 pm »
Juan, thank you for your extensive feedback (also your earlier post).
« Reply #43 on: August 19, 2016, 05:43:57 am »
All,
I was wondering ... Does the procedure work in the first place ?
I'm asking because I don't see any feedback so I just wondered. If it sounds like sh*t you can say it too, of course.
Procedure does not work for me.  The instructions are quite vague and can be read a few different ways so I am not sure if I have followed what you intended us to do precisely (well I probably have not it seems), but the boot procedure for my AudioPC is now dysfunctional and will only boot into W10565 by itself (which I have never used) regardless of what it is set to start into from XXHE boot menu.  W10-14393 is not available in the boot menu at computer startup at all.
I need the monitor back so I can work so currently have no functioning AudioPC.  Not sure what to do.  Are you able to write out a set of steps 1,2,3 from a known starting point?  That would be less cryptic.
« Reply #44 on: August 19, 2016, 07:42:26 am »
To add to this, I have figured out that I can boot into the various RAM versions ok (so long as they are not an expired OS) but as soon as I try to boot into any of the BASE versions (by setting it so in XXHE) W10568 RAM tries to load and of course that is an expired OS.
I need to boot into a BASE version to set the network mapping for the music and streaming directories.
