April 05, 2025, 06:02:20 am *
Pages: 1 2 3 4 5 6 7 [8]  All
Author Topic: Your first RAM-OS Disk Upgrade ! 14393.0  (Read 100069 times)
Robert
« Reply #105 on: October 20, 2016, 04:48:24 am »
Email Peter and he will send you instructions.
Robert
Oppo 205 UDP Dac
JLAudio 12 Active Subs x 2
« Reply #106 on: October 26, 2016, 10:44:25 pm »
After some modifications I'm now enjoying the 14393.0 version. The most important change has been to reduce the treble in my speakers by 3db. In my case I can adjust the level of the highs in the speakers, this way I managed to eliminate the excessive treble. I can imagine that if Peter could handle the software so it can regulate the treble, I think the 14393.0 version could be used without problems with a satisfying sound. The other change I've made has been the ClockRes to 5ms, otherwise the settings are Peter's ones.
I isolated the USB cable that goes from the Intona directly to the motherboard with an electrical tape in the same way that was previously isolated in the USB card and also have disconnected the grounding in the Audio Pc power cord. I know I have not the same computer as Peter (Stealth) but I can confirm that I have noticed a substantial improvement in SQ with all these changes.
Robert
« Reply #107 on: October 26, 2016, 10:56:09 pm »
Juan great to see a new post. I had my earth disconnected on my computer but noticed clicks when connecting USB cables and was getting small tingles of static electricity from the case(especially when I touched the case with my cheek one day fiddling with cables). I've since reconnected the earth, all fixed.
Interesting you have reduced Clockres to 5ms. I'm about to try that, I have the odd HD 24/96 download that is skipping randomly throughout the album. I'm not convinced its not the download but havn't had skipping in the past on these tracks. This is since I expanded Ram from 15 to 25g but also tried Peter's new settings.
Robert
Oppo 205 UDP Dac
Robert
« Reply #108 on: October 27, 2016, 03:22:55 am »
Tried changing Clockres from 15 to 10 then 5 then returned to 15ms. 15ms sounded the best with test files. Audible difference between the 3.
Robert
Oppo 205 UDP Dac
« Reply #109 on: October 27, 2016, 06:26:27 am »
Expanding Ram drive from 15g to 25g works and definitely sounds better.
Those who havn't done this and have 32g Ram do it now.
I've reverted DRAM back to Auto as some 24/96 tracks skipped mid song. Mind you not sure if this was the issue.
New suggested Peter's 14393 settings do work for the better also on page 5 of this thread.
So few comments I wonder what some people are doing!!!!
Robert
Hi Robert,
I've just built my new AudioPC and expanded the RAM-OS's to about 25GB and just started playing with 14393.  It sounds different to 10586 for sure, but I am not yet convinced it is entirely for the better.  Time will tell.
Page created in 0.023 seconds with 16 queries.
