April 07, 2025, 02:51:49 am *
Pages: 1 2 3 [4]  All
Author Topic: Check UAC  (Read 45307 times)
« Reply #45 on: December 03, 2016, 02:25:09 pm »
Something to add or otherwise I might forget for the next time :
What actually seems to happen is that there's no internal "administrator right" possible any more. I think this can best be derived from the normal command prompt still working, but "run as administrator" already comes up with the error message (see screenshots in previous posts).
I just noticed that even deleting or renaming a file throws a "You need administrator rights to do this" (similar).
With this knowledge I tried to get it going again for an hour or so, but I gave up and in comes the copy of the OS again ....
Btw the worse part is the necessity to insert the video card again in order to boot into a "service OS". So FYI, XXHighEnd Boot Menu also can't work in this state. Nothing works what's required in such situation. At least nothing I can find.
« Reply #46 on: December 03, 2016, 05:54:56 pm »
I'm all too familiar with this procedure. Were you just trying to delete a file or did the OS stop working so you had to reinstall the OS copy? If the latter, what do you think caused the OS to stop working?
Hoping to shed more light on prior problems.  Happy
« Reply #47 on: December 03, 2016, 05:58:18 pm »
Brian, as I told in the previous posts ... all it requires is setting the UAC up when in MinOS + Reboot.
But I just finished the procedure of XXHighEnd doing that for you, and which it disallows when in MinOS. Now all we need to learn is to stay out of the normal Windows functionality for that ...
« Reply #48 on: December 03, 2016, 06:02:04 pm »
Thanks Peter.
