April 07, 2025, 02:54:28 am *
Pages: 1 [2] 3 4  All
Author Topic: Check UAC  (Read 45310 times)
« Reply #15 on: August 10, 2016, 12:14:49 pm »
As often I am lost now. But : Put the ram-os in whereever you use it normally and in there go to normos. Then put back in the other pc if there is another pc in the firtst place (difficult to understand the situation).
It is regedit. Not regefit.
Tore
« Reply #16 on: August 10, 2016, 12:39:46 pm »
OK, where do i find normos?
The RAM-OS is back in my Audio-PC. The Audio-PC have a SSD with the OS original
« Reply #17 on: August 10, 2016, 04:18:49 pm »
Normos = Normal OS.
Tore
« Reply #18 on: August 10, 2016, 04:30:45 pm »
one more time: But i`m in Min. OS, is it posible to go to Normal OS when i can`t open XX?
« Reply #19 on: August 10, 2016, 07:15:16 pm »
Nope. nea
« Reply #20 on: August 11, 2016, 01:23:28 am »
I am ignorant about the way the OS is minimized, so I hope you will forgive me if my suggestion does not make any sense...
Is it possible to have a script that could enable the needed processes to go "almost" back in normal OS mode ?
Sorry if this does not make any sense...
« Reply #21 on: August 11, 2016, 07:01:15 am »
Hi Alain,
None of this should be necessary. It never happens to anybody, and it is my guess some strange kind of disk swapping has been going on. Now if you can get Tore to tell what this is with not too many language problems Wink, we would be a few steps further.
My guess : somebody tried to copy XXHighEnd data from one disk or folder to another. That violates the Activation. Next it is the Windows 10 bug (?) which does not allow to start RegEdit (??).
Tore
« Reply #22 on: August 11, 2016, 10:26:12 am »
the only different now that i can remember is the REGA DAC and new DAC settings in XX 2.06.
I was playing some tracks and picked the Min. OS button. After that reboot XX started to telling me to check UAC and reboot. (not posible to open XX.
Then the RAM-OS went out and the SSD OS went in.
I started XX 2.04 and played one track. Then i picked the Min OS button and now i have the same problem with my SSD
Tore
« Reply #23 on: August 11, 2016, 12:24:06 pm »
I have an emergency this morning and since I am back at work (after 2 weeks of vacation) I am short on time... I will try to find the time to formulate some questions later this evening...
All I can say at this time is assuming that:
- The ram-os drive is the original hard drive.
- It is used and located on your one and only Audio PC (the one in your signature).
- The 2.06 XXHighEnd version (and the 2.06a patch) were installed on your Windows 10 build 10586.0 version (at least) and it has worked well with your NOS1a before.
- It is still activated (but this seem impossible to verify at the present time) with a RED title at the top of the XXHighEnd Window.
The questions that I think of for the moment are: is there something that you did apart from switching the NOS1a to the Rega dac and adjusting the settings to have it work ? I assume it was working before you went in Minimized OS ?
Tore
« Reply #24 on: August 11, 2016, 12:38:50 pm »
Alain, all is correct (Windows 10 build 10586.11)
Everyting was working fine in Min. OS until the NOS1 usb failed
Tore
« Reply #25 on: August 11, 2016, 01:06:40 pm »
HI Tore,
I am about to leave for work, so I may only be able to check later in the day Happy
You did not mention that USB fail (at least not in this topic)... I fail to see how this can be related to the UAC problem though... I can start XXHighEnd even it the NOS1a is disconnected or turned OFF.
But if that relates to the actual problem, maybe you could try another USB cable, another USB port, removing the Intona temporarily, deactivate the USB port that does not seem to work through Device Manager...
I was not aware that the build is 10586.11... Isn't it supposed to be 10586.0 ? Have you updated your Windows 10 version too ?
« Reply #26 on: August 11, 2016, 01:12:25 pm »
I forgot to suggest... Is it possible for you to copy the ".vhd" file that you normally have in copy over your actual ".vhd" file and restart from there ?
Don't forget that if you haven't changed Windows 10 build 10565 yet, you may need to change the date by putting it back a few months behind...
You may also need to connect a keyboard, mouse and monitor directly to your Audio PC to redo a few things...
I have to leave now... Happy
Tore
« Reply #27 on: August 11, 2016, 05:32:23 pm »
Alain,
usb problems: http://www.phasure.com/index.php?topic=3675.0
My NOS1 (+ ram-OS) is on the way to Peter now
Windows 10 build 10586.11 is because Windows automatic started a update :-(
About Windows 10565, do i have to do anything with it when i never use it?
Tore
« Reply #28 on: August 11, 2016, 05:36:13 pm »
Hi Tore,
Sorry it took me some time to understand unhappy
AS for build 10565, since it was suppose to end its life July 29th, you should normally go back in time. I changed the date in another Windows (from the ram-os drive), but be sure the date is changed before attempting to load build 10565...
« Reply #29 on: August 12, 2016, 08:30:36 am »
No ...
but
You would use it to boot from and copy back the "Copy" OS file which is in there, so you'd have the normally running 10586.0 back ...
