April 07, 2025, 02:12:17 am *
Pages: [1] 2 3 4  All
Author Topic: Check UAC  (Read 45295 times)
Tore
« on: August 09, 2016, 10:39:17 am »
Hi, can anyone help ?
My setup is with a Music PC and a Audio PC
When i try to start XX on the Audio PC i get the message to Check UAC and reboot over and over again (not possible to start XX)
UAC is off on both PC`s.
It is not possible to open "Change User Account Control Settings" on Audio PC (is in Min. OS?)
Tore
« Reply #1 on: August 09, 2016, 02:21:08 pm »
Tore, it is not easy for me because I am at a poor Internet connection at where I am, but manually (RegEdit) set this key to 0 :
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System
EnableLUA
Tore
« Reply #2 on: August 09, 2016, 03:48:13 pm »
Peter, i hope you are in a warmer country than norway  wacko bzz
I get this message: the service cannot be started, either because it is disablet or because it has no enabled devices associated with it
Tore
« Reply #3 on: August 09, 2016, 04:52:35 pm »
Ah ... For this all go to Normal OS first !
Please notice that this UAC thing could be a 2.06(a) bug. I only noticed it myself 3-4 days ago.
I hope it helps !
Tore
« Reply #4 on: August 09, 2016, 04:59:24 pm »
It is not posible to open xx so that i can go to normal OS
Tore
« Reply #5 on: August 09, 2016, 05:15:35 pm »
I recall the similar situation.
A bit difficult to sort out on my phone, but I recall now that I shifted UP the UAC slider (plus reboot) to overcome the situation. But I forgot the situation.
I will be out soon;
What actually is it you are trying to attempt ? It does not look like normal installing to me ...
Also, at what thing you do you are getting this service disabled message ?
Tore
« Reply #6 on: August 09, 2016, 05:34:20 pm »
I`m trying to play music with a Rega DAC
Also, at what thing you do you are getting this service disabled message ? Audio PC in Min. OS
It is not possible to open "Change User Account Control Settings" on Audio PC, is it because of min. OS?
Tore
Tore
« Reply #7 on: August 09, 2016, 05:42:32 pm »
the problem started with this message from 2.06 : Music root does not excist
I found out that the external HD in the Music PC was not shared with everyone. I think it was because a windows update on Music PC
This is OK now
« Reply #8 on: August 09, 2016, 05:57:07 pm »
[]Also, at what thing you do you are getting this service disabled message ? Audio PC in Min. OS
I meant : What do you do to get that message ...
Just open user acc control ?
If yes ...
]It is not possible to open "Change User Account Control Settings" on Audio PC, is it because of min. OS?
Yes, that is what I recall.
Tore
« Reply #9 on: August 09, 2016, 06:01:54 pm »
I got that message when i tryed to open Regedit on Audio PC
Tore
« Reply #10 on: August 09, 2016, 09:51:08 pm »
the Ram-OS HD went out and my normal HD went in.
I played one song and picked the Min. OS button (XX 2.04)
After the reboot i have exactly the same problem, not posible to open XX 2.02, 2.03 and 2.04. (just telling me to check UAC and to reboot)  Sad
« Reply #11 on: August 10, 2016, 08:37:32 am »
But now you can open Regedit ?
Tore
« Reply #12 on: August 10, 2016, 09:17:24 am »
No way, i get the same message (min OS)
« Reply #13 on: August 10, 2016, 11:50:11 am »
Misunderstanding : Regefit in Normal OS I meant. But maybe I make no sense...
Tore
« Reply #14 on: August 10, 2016, 12:05:21 pm »
Run - regefit = Windows can not find regefit
But i`m in Min. OS, is it posible to go to Normal OS when i can`t open XX?
Tore
