November 23, 2024, 08:17:42 am *
Author Topic: PC can`t find NOS1  (Read 20168 times)
Tore
« on: July 31, 2016, 10:14:36 pm »
Tore,
But i was so stupid to pull out the USB cabel and now my PC can`t find my NOS1
At first I thought that you pulled out the cable when music was playing. But was music playing indeed ? Or did you just change the cables as you just described as everybody could do that ?
If you pulled out the cable when music was playing, which side of the cable did you pull out first ?
« Last Edit: August 03, 2016, 02:19:28 pm by PeterSt » Logged
« Reply #1 on: August 01, 2016, 08:11:15 am »
Hi Tore,
Hmm ...
Did you switch off both the PC and the NOS1 (and restart them) ?
I think you also have an Intona; did you try it without that ?
Tore
« Reply #2 on: August 01, 2016, 08:54:57 am »
Peter, i have restarted both many times. I will try without the Intona later.
Tore
« Reply #3 on: August 01, 2016, 07:47:19 pm »
Peter, i have been out today
It is no difference without the Intona :-(
At the bottom of the Phasure USB Audio Control Panel : Ready + Driver not is available
Tore
« Reply #4 on: August 02, 2016, 08:53:44 am »
Tore, maybe it is quite a detour for you, but can you try another PC ?
All you need to do is install the Driver and watch for "Streaming is up and running". No need to install XXHighEnd.
Tore
« Reply #5 on: August 02, 2016, 09:35:00 am »
I will try another PC later, i don`t have so much time today
In Control Panel, Devices and Printers the NOS1 is marked with this text:
Unknown USB Device (Device Descriptor Request Failed)
Tore
« Reply #6 on: August 02, 2016, 01:22:29 pm »
Tore,
I Recognize that description from (indeed) a failing USB device. But this can happen at the PC side as well as the DAC side.
You can also try to reboot into Normal OS (first to BASE !) and reinstall the driver. But testing another PC is the fastest and most reliable.
Tore
« Reply #7 on: August 02, 2016, 02:19:28 pm »
Peter, i have done this but it did not help: You can also try to reboot into Normal OS (first to BASE !) and reinstall the driver
Tore
« Reply #8 on: August 02, 2016, 02:56:46 pm »
Do notice that if you did not do this *OR* if you after this reinstalled the Driver in MinOS, all looks fine for the Driver Install, but it will NOT work (until you boot into Normal OS again).
Please take notice of this carefully.
Tore
« Reply #9 on: August 03, 2016, 09:50:02 am »
I have tried to instal the driver to a W10 laptop many times but installation failed?
Tore
nik.d
« Reply #10 on: August 03, 2016, 10:18:09 am »
Hi Tore,
Pls try foll:
Remove IEC power cord from NOS1 for a minute or two then plug it back. Power on NOS1. Looking through the slits at NOS1's left 'leg'
there should be visible green light from small LED. If there's no LED lit, USB/I2S receiver needs repair. How this could occur (with Intona
isolator in place) is really a mystery...
« Reply #11 on: August 03, 2016, 10:38:35 am »
George (nik.d), I think with this type of error the led will lit anyway.
Tore
« Reply #12 on: August 03, 2016, 10:45:23 am »
Hi George!
The green LED is OK
Tore
« Reply #13 on: August 03, 2016, 10:45:56 am »
How do you know ?
Btw, you can short cut the communication about this by telling what goes wrong, where it goes wrong, error messages and all you can imagine I like to know.
Oh ... I now recall ...
1.04 will not install unless you let XXHighEnd apply the "no Signed Drivers" thing.
1.03 should be OK. So try 1.03 !
Tore
« Reply #14 on: August 03, 2016, 11:26:50 am »
1.03 was installed successfully on the laptop. But the laptop comes with this message when i connect my NOS1: Windows do not recognice the device and it has i fail
Have to go out now
Tore
Page created in 0.109 seconds with 19 queries.
