November 23, 2024, 05:05:11 am *
Author Topic: Remote Desktop problem - cursor shows on Audio PC  (Read 7463 times)
Stanray
« on: July 29, 2016, 09:12:18 pm »
My Audio PC is controlled by my MusicServer PC by means of Remote Desktop and my MusicServer PC is controlled via Remote Desktop on My iPad.
This worked flawlessly when my MusicServer PC ran on Windows 7.
I tried another HDD in my MusicServer PC that runs Windows 10 and although I still can make the connections from iPad > MusicServer PC > Audio PC I can't control the Audio PC and XXHighEnd properly because the Audio PC shows a mouse cursor and therefor the touch functionality doesn't work. This happens in Minimized and Normal OS.
On the MusicServer PC Remote Desktop on the iPad works OK.
Any ideas what could be wrong?
Stanley
Stanray
« Reply #1 on: July 30, 2016, 01:16:49 am »
Ah, I found a small grayish menu on the top of the Audio PC desktop (hidden underneath a similar menu of the MusicServerPC desktop). Hitting that shows a toggle possibility between Mouse and Touch on the right hand side of the screen.
Restarting Remote desktop brings the default to the Mouse mode and not the Touch mode, which is not convenient.
Stanley
« Reply #2 on: July 30, 2016, 07:34:22 am »
Hi Stanley,
I take it that the problem has been solved now, right ?
Question : Is this with Remote Desktop from Miscrosoft (on the iPad) ?
All I want to say is : with RD such settings do not exist that I recall. With anything (??) else it is a settings - not sure even why because it is never useful and always confusing.
Stanray
« Reply #3 on: July 30, 2016, 11:45:05 am »
Yes, Microsoft Remote Desktop on the iPad.
Solved? Well more or less, it works, but not as smooth as under Windows 7 on the MusicServer PC.
I think I install the Windows 7 disk back in the Music Server PC. I can't see any advantages in using W10 in the Music Server PC.
Stanley
« Reply #4 on: July 30, 2016, 12:42:05 pm »
Stanley, be careful that it is not about lacking video drivers. RDC can be quite picky with that.
