April 01, 2025, 12:36:08 am *
Pages: 1 2 [3]  All
Author Topic: Stealth PC - ** BE WARNED **  (Read 51617 times)
« Reply #30 on: March 28, 2017, 07:00:07 pm »
I use the short Clairixa, OK ?
haha
Rmalits
« Reply #31 on: March 29, 2017, 12:01:04 am »
yes, plug in the short one first. But the long one could be even more effective  whistle
My new audio PC got a new name: I call this machine "Diva".
She is a pretty capricious Diva!
When she is in a good mood she plays like hell and creates a sound stage larger than my living room.
When she is not in such a good mood, I have to plug in and out something... that helps  Hips - oops
It's unbelievable how capricious Diva behaves. In the beginning she was harsh and abrasive, she didn't provide me any (b)ass... ha ha ha
Plugging out and in the Intona helped her a lot to become more approachable, but her tonality was still on the hard side for two weeks or so...
Now she sometimes acts preety mellow. And again... plugging the Intona into her other port gets her back into the nailing mood  clapping
I am pretty curious what comes next...
Kind regards
Richard
« Reply #32 on: March 29, 2017, 09:22:18 am »
Well Richard ...
You are most certainly right that this brings a h*ll of a change.
I think you will recall how my sound is; say about the "so clear !". Now envision that with your found application there's indeed this larger stage, up to being in a church somewhere. Would that imply better clarity ? I don't think so. Could it be messy because of all the hall ? I think it can.
This is what happens over here and it lasted about 45 minutes + 10 to die out.
Haha, the latter is no yoke because it seems indeed to be so that there's this after-effect. It was good that we were warned for it or otherwise I maybe wouldn't have known where to go. Anyway, I'd say that after one minute or so of pulling out the Intona, the effect started to diminish and after about 10 minutes I was completely happy again.
Explanation :
Without being able to see any of this (I did not attempt that either), it looks like something in the OS is trying to do something with that actually failing USB connection. Even at the hardware level something of that could be going on, but I think software because of the dying out nature. Thus, some process of "investigation" is started by the OS, which stabilizes because continuously no answer (while the Intona still always talks back, but with a dissatisfying answer) and this process keeps on running when the Intona is pulled out, but now once in a while looks if something is going on again, doing that less and less until all is sure that nothing will come of it any more.
Btw, I made up this scenario already after your first post about this, again saying that I believe all you people find out and tell about.
Judging the proper merit is often difficult because also personal (or better : it is difficult to take distance from personal / subjective ideas about it all) and already my "urge" to make judgements "general" for you all (try to read that I claim to be objective - hahaha) could indicate that your opposite judgement is the dangerous one. But an example which could be part of the guidelines :
If this was figurative then I say nothing. But if it was intended to be literal then your guideline should be that such a thing is impossible. And if it happens anyway, some "DSP" is doing it to you. Of course no real DSP in this case, but something with the effect of making all larger up to illegally large. For myself I could say : when I'd have instruments outside of the walls of my listening room, I would soon be ready for hospitalization or wear such dark sunglasses that I can not see the walls of my room.
Of course you spoke figuratively and I only wanted to give an example of failure.
Many people in here know about the examples of listening rooms which start to sound like churches, and almost always this is about the spread of energy which is the opposite of accuracy. So, the "so clear !" springs from accuracy and pinpointed bells and twinkles and things. Spread that bell and you will be in church but the bell becomes a mastodont.
Lastly, this is of course how it expresses over here. I am per se not saying that in your situation it happens the same because, for example, first something else may have narrowed the sound stage and this now could balance out nicely. Still, keep in touch with it and don't hesitate to come back with the announcement that it did not work out after all. Or, that in a month's of time you are still super happy.
And again : thanks !!
« Reply #33 on: March 29, 2017, 11:05:21 pm »
It may or may not be useful, but one thing that I noticed when I packed up my DAC to send over to you (i.e. I have only noticed it once and never really looked into it) is that the USB/Intona apparently draws power from the 5V Standby off the mobo.  With the Intona plugged into a mobo USB port try the following....turn off your AudioPC, but not at the wall, make sure that 5v standby voltage is still being applied...watch the lights on the Intona continue to blink when the computer is shutdown.  Of course i noticed this with a standard non-stealth PSU so your situation could be different, or perhaps it is just some caps in the Intona slowly bleeding out, but it my situation the Intona keeps flashing on and on until I turn off the PSU at the switch.
« Reply #34 on: March 30, 2017, 07:07:22 am »
Hi Anthony,
Now you say it ... yes, I noticed that but I never gave it a thought.
I guess it should be so that the USB port of concern is one you can use to charge batteries ? Such ports stay live and this is on purpose.
Btw I recall that officially the red USB ports are for that, but I wonder whether I have ever seen them on MoBo's. So now it is just guessing, or by now all USB ports can serve that purpose ?
Besr regards,
Rmalits
« Reply #35 on: March 30, 2017, 11:39:30 pm »
Hi Peter, Anthony and others...
thanks a lot to you Peter for your so detailed explanations!
An important point for me is: I am not talking about distortion, hall effects or something similar, when my Diva - Stealth Mach II - is acting in her best way. It's the clear, clean sound what makes it so impressive and so pleasant to listen.
The size of the sound stage is not so important here. So let's discuss that maybe later.
When my Diva is not doing well, SQ is becoming slowly worse and worse. That happens so slowly that you would realise it after hours, or next day or after an even longer period. Especially more complex music tracks with higher frequencies are effected by low precision, kind of smearing, ... what makes the listening pretty anoying.
I never ever used an hifi equipment with such variable SQ!
In her good hours I would give Diva&NOS1a 99 points out of 100 without any doubt about it.
When she is in her bad mood she get's not more than about 10 out of 100. It's a huge drop of SQ. The sound becomes more and more inaccurate. This doesn't happen within 10 minutes, it takes a day or so, I guess, to get her there.
The good point is, that there are means to bring her back to the "make me happy" mode. I mentioned the procedure to plug in / plug out the Intona (in line or into another USB port). I tried this more often recently and found out that it doesn't always help. Sometimes the sound may change even a little to the worse when plugging the Intona into another USB port, but only a little bit (maybe a change 5%). Peter, that's probably the same what you experienced.
This afternoon it was like that, I was not happy at all with the SQ. E.g. Al Di Meolas album "Splendido Hotel" was hard and anoying to listen. Plugging in/out the Intona didn't help. So I thought... ok, it's Windows running on this PC. Maybe it just needs a reboot (as PCs running Windows need it quite frequently, right?). So I rebooted Diva and during that reboot I switched off and on my NOS1a too and set the DC offset as always.
And... bingo! Diva was playing nicely and precisely again. Incredibly good SQ. She was doing that for some hours. No it starts to get slowly worse again.
What I realised later is, that I forgot to take out the Intona when doing the reboot, what's interesting.
All that is still pretty confusing... Hard to say, if these effects depend on somehing physical like the 5V USB voltage or on software activities.
What I will do in the near future: Reboot the the PC and switch off/on the NOS1a whenever I am not happy with the sound. And I will try this with and without the Intona plugged in.
I wonder why I haven't got this idea earlier...
Important point concerning all this: Peter, as you suggested a few month ago I keep all this equipment running for days, weeks and even longer without switching it off even once. What I also do is: I let a long playlist run in lower volume, when I am not listening (amplifiers switched off).
So maybe that's too much for a Windows based system(?). We will see...
Once more I have to state: When my Diva is doing well, I am most likely one of the most happy music listeners on this planet. I am sure we will find a way to make her always going that way.
Kind regards
Richard
Richard
« Reply #36 on: March 31, 2017, 08:51:39 am »
Dear Richard,
Actually because of a lack of time, I did not write yet what I am going to write now. I even wanted to open a new topic for it. ... OK, I am going to do that anyway. You will see it appear somewhere automatically during this day.
« Reply #37 on: March 31, 2017, 01:15:26 pm »
Here's what I wanted off my chest :
After a while SQ degrades - how come ? what to do ?
Pages: 1 2 [3]  All
